Results 1 to 4 of 4
Thread: New Rear brake shoes - '94 R100GS
    Apr 2006
    Anybody in St. Louis MO area planning to do this fairly soon on a similar model bike (wire/rod activation of rear brakes) and willing to have an adult male observer/helper???
    I am mechanically OK but hate to do something new without having seen it done once (at least).
    I promise to keep quiet and not touch anything until you request so.
    Ed
    macsfriended@hotmail.com
    North Georgia Mountains
    Exclamation Brakes
    It's not difficult. Remove the rear wheel. Remove the springs on the brake-shoes, taking care to mark which is which (sometimes, one is smaller than the other). Remove shoes. Clean the backing plate assembly with spray brake cleaner. Remove the cam-rod (the shaft that connects the brake-cam to the external lever) taking care to note the location of any washers. Clean the shaft, and grease, using SMALL amounts of high-temp grease (just wipe some grease on the shaft). Clean the brake-drum with spray brake-cleaner. You might wanna feel of it, to see if it needs to be resurfaced. A machine shop can resurface it with a milling machine, without dismounting the tire. Tell them to take off the BARE MINUMUM of metal! In any event, scuff up the surfce with fine-grit (400 or finer) emery paper, re-clean. Re-install everything in reverse order. Break in the new brake shoes with gentle use for the first 50 miles or so, and then give them 10-20 second bursts of harder braking, under power, to finally seat them. They will give improved braking performance over the first 100 miles. Don't hammer them when they are brand-new; they will glaze over.
    Roger Wiles
    roger@rogerwiles.com
    www.rogerwiles.com
    706.897.8266 24/7 Wireless
    Apr 2006
    Quote Originally Posted by 56231
    Ed
    You wore out a set of rear shoes on a GS? WOW! At 99K miles, mine are getting thin, but are still serviceable.
    elderly Brake Shoes
    Quote Originally Posted by mwoods
    They don't wear out, so much as they get old and hard, and won't stop anything.
    Roger Wiles
    www.rogerwiles.com
