Results 1 to 7 of 7
Thread: Tire Pressure System Possible Malfunction
    Feb 2013
    I have a 2008 R1200 GSA with the tire pressure monitoring system. Although the tires are correctly inflated when I first start out on a ride everything is fine. Approximately 10-15 minutes into riding the tire pressure system alerts that both from and rear tires have no tire pressure. The yellow warning light illuminates and on the gauge the pressures read as dashes. After another 20 minutes and sometimes a stop or two it resets itself and everything is fine.
    Any ideas why this is happening?
    Thanks for your help.
    Debbie's Servant Lee's Avatar
    SW Iowa
    Maybe the batteries in the TPMs are are close to wearing out.
    Lee 2011 K1300S
    MOA # 30878
    Aug 2006
    Southern California
    Plus 1.
    When I had my recent tire incident, the warning was flashing RED triangle. Your yellow triangle is likely notification of a system problem, probably battery.
    Feb 2013
    Thank you.
    Thanks to all for the advice on the tire pressure issue. Here is a good one: The dealer was not aware that the sensors had batteries.
    Registered User wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    i had a similar problem with my front TPMS sender....2013 RT.....apparently the sender and receiver can have a slight hiccup.....took it to BMW MC of Long Beach and they re-flashed the sender and receiver...all is good now....and i asked about the NON-changeable batteries....response was it is impossible to seal the sender....
    2013 R1200RT - Sassy - Fluid Grey Metallic
    2002 V-Strom DL1000 - sold
    2008 KLR650 - sold
    Here's a little engineering information based on my experience in the USA nuclear weapon complex.
    There's such a thing as a "certified part."
    Certified means the actual engineers that designed the part have visited the supplier that produces the part, observed the process, possibly participated in assembler personnel training and surely in designing the assembly process, tested a valid sample of the output, and perhaps set up an ongoing test program.
    The TPMS sensor is a critical safety-related component, and to design them in any fashion that would allow shade-tree mechanics or other near blacksmiths to maintain them, such as replacing batteries, simply does not compute in the world of real engineering. It's replace with another part only. I'm sure this is BMW's position as regards the old whizzy ABS pumps, too. Those now offering repair service better have good liability insurance. Do you want to be rich but injured?
    So, before grousing about the cost of this, consider the service you've been provided by these processes.
