Results 1 to 15 of 27
Thread: Big oil mess
    Registered User 88bmwjeff's Avatar
    Aug 2004
    Walnut Creek, CA
    Big oil mess
    We've had a heat wave here, and the plastic jug I bought for used oil storage (yeah it was designed for it) burst dumping a bunch of oil on the floor. Any suggestions on how to clean up the mess. Luckily it's in corner where I don't travel much. I wont have time until this weekend to clean it up.
    Jeff in W.C.
    1988 R100 RT (the other woman)
    "I got my motorcycle jacket but I'm walking all the time." Joe Strummer
    Registered User greg's Avatar
    Jun 2014
    Central Valley California
    Nitrile Gloves and lots of brake cleaner.
    Soak up as much as you can with paper towels then start with the brake cleaner. Depending on the finish of the concrete it should get all of it.
    Greg
    South Central Valley, CA
    2014 R1200RTW, 2013 Paiggio BV350, 2010 Yamaha TW200
    Administrator 20774's Avatar
    Throw down some kitty litter...maybe some laundry soap like tide powder.
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    That works most awesome.
    1986 K75S(the beutch), 1993 K1100RS (blown engine), 1997 Chev Short Box (4x4 with an LT1)
    "You can easily judge the character of a man by how he treats those who can do nothing for him."
    na1g
    May 2011
    Greater Bahstin, Massachusetts
    +1 on the kitty litter (speedy-dry) and powdered detergent (not soap). Works great on oil spills (don't ask!)
    And thanks for bringing up the issue of storing oil in hot weather. It's upwards of 95 here right now and the oil was put in a jug back when the temp was around 50 so there has been some expansion. And since I drained exactly 4 L out of the RT, poured 4L of new oil into the RT, and then poured the used oil into the 4L jug, there isn't any room for expansion. I'm going out to the garage right now to check on the jugs. Great, now I have to check used oil pressures in addition to tire pressures.
    pete
    May 2006
    Northern New Jersey
    I predict before we are done here, we'll have a brand new oil thread- "What is the best container to store your used oil in during hot weather?" "And does it matter if it's regular or synthetic?".
    Watch This!!! junkjohn's Avatar
    Feb 2010
    Dennis, MA
    Also rub the kitty litter with a brick and really grind it in. You will be amazed. Then I would try the brake clean.
    John Simonds
    2008 R 1200 GSA
    1975 850 Norton Roadster
    If it ain"t broke... fix it till it is.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    As with anything, the longer you wait to clean it up, the more stain will be left. There will be a permanent stain by this weekend.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Nov 2011
    Central Ohio
    Quote Originally Posted by ClassicVW View Post
    Don't know what is best, but a gallon milk jug is one of the worst. Seems to break down within a week or so after filling with oil, regardless of temperature. Recycle ASAP.
    Larry
    2006 R1200RT
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    What do we do when the jug's sight glass blows out???
    and is it ok if the level is an eighth-inch above or below the dot?
    Apr 2006
    For those that play with wood, sawdust works great too.
    2010 F800GS Full Ohlins package, '04 R1100S Replika
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Tuscany and Central Italy 2010
    Apr 2012
    Gilbert, AZ
    I use a five gallon plastic gas can, one of the red pre-EPA models. When it's close to full I haul it to the local FLAPS and dump it in their recycle tank. I've used it for several years without incident and it gets pretty warm around here in the summer (114F today).
    Kitty litter works great for oil spills.
    1983 R100RS (Sold)
    2004 R1150RT
    BMW MOA 181289
    ABC 13558
    Survivor akbeemer's Avatar
    Jul 2007
    Land of the Big Sky
    I use the five gallon plastic jugs that the kitty litter comes in.
    If you use the Brake Cleaner in significant amounts and in an enclosed area you should use an appropriate respirator/protector.
    Kevin Huddy
    Intrepid Incompetent
    Tm Pterodactyl MT Outpost
    Eastern KY
    Not to sound as if "I know so much" but oil spills are everyday in a shop & oil cleanup with clay (aka kitty litter) is old stuff. Why pay more for kitty litter-is there some reason to have perfumed oil spills???
    Wally world sells clay in a bag as does most AP stores & costs less.
    Beware!-sawdust works OK but becomes flammable after oil soaked so careful you do with the contaminated sawdust! Not many "good places" for oil soaked sawdust. There was a time when it was fairly common the use it for floor sweeping to pick up dust-OHSA stopped that practice, as did common sense/fire safety.
    Paper towels-why cut down a tree to clean up oil? newspaper would do the same thing but still your dumping oil into a landfill-a nono! Honestly, I don't know where the leftover cleanup stuff (like clay) should go?
    I save dirty oil in the jugs it came in & dump at AP's store in the back. I "get ahead" on "dirty oil space" via 5 gal pails from lacquer thinner buys or paint pails.
    "If I had my life to live over, I'd dare to make more mistakes next time...I'd relax,I'd limber up... I would take fewer things seriously...take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges at age 85.
    Aug 2004
    Walnut Creek, CA
    Quote Originally Posted by na1g View Post
    pete
    Keep in mind, I had purchased a large used oil container at the local hardware store. While I had filled it up somewhat, it was still mostly air in there. I'm sure it was the air that expanded to burst the container and not the oil.
    Jeff in W.C.
