Results 1 to 5 of 5
Thread: K1100Lt 1995 Final drive and transmission oil -
    Apr 2005
    Quebec, Canada
    I plan to change the oil of the final drive and the transmission on my K1100LT 1995.
    I have a leftover (3/4 of a liter) of unused oil (grade 80-90) that I bought in 2008.
    Any counter indication to use this ?old? (2008) new oil?
    Thanks.
    JPK1100
    Oct 2003
    "Big Bend" TX
    Assuming it was stored sealed - so as to not get contaminated with crud, grit, dust, and debris, and assuming it is GL5 rated 80w90 gear oil I think it would be fine to use. You won't have enough to fill both the transmission (850cc) and the final drive (about 150cc I think) - so will need another bottle anyway. So you will then have maybe 1/2 a bottle of the new stuff left when you are done.
    Apr 2005
    Quebec, Canada
    Assuming it was stored sealed - ...
    Well... there always was a cap on the bottle.
    Many thanks Paul.
    JPK1100
    Oct 2003
    "Big Bend" TX
    Quote Originally Posted by jpk1100 View Post
    Many thanks Paul.
    JPK1100
    I buy gear oil in gallon containers. I once bought a 6 gallon pail with pump. It takes a while to use it up and I don't think any ever "went bad".
    Apr 2005
    Western New York State
    My dad always said"Oil is cheap". Any doubts? Spend a few bucks buy a new jug. Would you rather use old oil and spend BIG bucks for a new FD or Tranny?
