Results 1 to 4 of 4
Thread: 05 K1200lt center stand problems
    Question 05 K1200lt center stand problems
    Ive got a low mileage 1200lt with center stand problems, starts to go down then stops when it tries to lift the bike. Had a small drip of oil underneath it after winter storage so seems like there is a seal gone. First, where does it draw the oil for hydraulics from, and second, how difficult is it to change the seal. The BMW shop manual tells you nothing. You can get hold of me at kmh@politiriaviation.com if you have any ideas that may help me out. Love you guys.
    Maryland
    Just looking at the parts fiche shows that there are no parts for the actuator. The whole actuator is over $1100. At least there are no parts sold by BMW. It may use a part that you can get at a local bearing/seal supplier.
    2004 R1150RT 145,700 miles
    1991 K100LT 126,700 miles
    1982 R100RT 106,900 miles
    Total 379,300 BMW miles
    Here's some info from over on BMWLT:
    cws
    Senior Member
    Re: Electric center stand K1200LT
    Joe's original article with updated notes about oil amounts
    http://www.bmwlt.com/files/displayim...album=15&pos=7
    Ari's pics and descriptions
    http://www.bmwlt.com/forums/showthre...highlight=EHCS
    My video on how to quickly remove the EHCS, without disturbing the tupperware
    http://www.youtube.com/watch?v=Ey7siMk-XSs
    Bighoppers thread about fixing a cracked EHCS case
    http://www.bmwlt.com/forums/showthread.php?t=46384
    The replacement starter motor, just US$37.95
    http://emsglobaldirect.com/p-820-hs-50n.aspx
    __________________
    Chris
    Sydney, NSW
    2005 Dark Graphite Metallic K1200LT
    2005 Orient Blue Metallic K1200GT SE
    Ulysses #45310
    GS911
    Maryland
    I found this PDF that looks to be good.
    http://www.nt-guru.com/bmw/k1200lt/C...%20Circuit.pdf
    It has part numbers for the seals and a supplier.
