Results 1 to 15 of 16
Thread: 2013 R1200 RT - Anyone replace the radio antenna?
    Registered User natrab's Avatar
    Sep 2012
    Oakley, CA
    There are a few things I like about the new antenna compared to my '06, the first of which being the base is properly mounted and doesn't get loose or rotate. It's also nice that you can adjust it's angle. The big thing that bugs me however is that the antenna is not really stiff enough. They made it thinner and made of a heavier metal compared to the old plastic one. This makes it a bit "floppy" while at speed or in wind. The wind tends to make it whip around a bit. At speeds around 80mph with wind it can seem to whip all the way back to the point I'm worried it's going to mar the little painted panel below it. I know it's naughty, but at speeds 90 and 100+ it starts to oscillate rapidly and just becomes a blur and once again seems like it's going to smack that painted panel.
    Since the antenna screws off from the base, I was wondering if anyone has replaced it with something aftermarket? I wonder if anything with matching threads will work for it, though I don't really know how to measure the threads. I also don't know if the XM radio uses that antenna or if it has another hidden somewhere.
    Nate R
    2013 R1200RT 90th - "Tyr" - Purchased 12/13/2013 brand new!
    2007 R1200S - "Sexy Beast"
    2006 R1200RT "Wōden" - 84k - Retired and sold
    Albuquerque, NM
    The usual supplier for antennas on German vehicles is Fuba. This is a Fuba antenna.
    There are plenty of replacement masts available, including short stubby ones.
    I'd search Fuba and also suppliers for aftermarket goodies for VWs. On VWs you'll note them on the roof extending over the rear window and sometimes called bee stingers.
    Kent Christensen
    21482
    Sep 2012
    Oakley, CA
    Great info! Thanks. I'll see what I can find.
    Nate R
    Larry xlarry's Avatar
    Nov 2013
    Richardson, Texas
    Quote Originally Posted by natrab View Post
    I have a '13 RT and mine does not flop; it does move a little but not even close to the point of hitting anything. Wonder if they changed it at some point during the model year?
    Larry
    Midnight Blue 2013 BMW R1200RT (purchased 9/24/2013)
    2010 Harley Road Glide (gone after 61,964 miles)
    2001 Harley Electra Glide (gone after 138,048 miles)
    St Paul
    ant.
    I had a 12' (I was T-Boned) and now have a '13. I believe the antenna are the same on both bikes. I am not sure but I would believe that the sat. ant. is different. It is a much higher band wave and uses different style of lead in.
    May 2008
    Bend and Portland, Oregon
    Airflow off the windscreen can also affect the antenna. When I bought my 2012 it had a larger Calsci on it and the antenna would go wild at higher speeds... after installing the stock screen back on.. no movement at all, or very little.
    Sent from my DROID4 using Tapatalk
    2012 R1200RT
    2012 Super Tenere
    2001 R1100RT (sold)
    Registered User oldspice's Avatar
    Nov 2012
    I have the same issue with my '12, but only when using an aftermarket shield. I have 2 Cee Bailey's shields, a short sport shield and a standard sized shield (+1") and I get the violent oscillation that you speak off with both of those shields. And I don't need to get up to 80+ to get the oscillation - it happens for me at anything above 50.
    Please keep us posted as to what you find in terms of a shorter, more substantial replacement antenna. There's a guy over on the BMWLT forum that cut is OEM antenna down, but that was for cosmetic reasons, I believe. I'm not willing to go that far just yet.
    "Looks like I picked the wrong week to stop sniffing glue..."
    Current ride: 2012 R1200RT
    MOA #175432
    BMW RA #41108
    Registered User Hodadd's Avatar
    Apr 2014
    Central Coast, CA
    Quote Originally Posted by bernie View Post
    Isn't the sat antenna and the radio antenna one and the same? I don't know, but the antenna has dual windings as if doing dual duties.
    Quis custodiet ipsos custodes? - Juvenal
    (Who watches the watchers)
    Albuquerque, NM
    SAT antenna is a separate unit and not visible without removing some fairing.
    http://www.realoem.com/bmw/showparts...20&hg=65&fg=21
    Kent Christensen
    21482
    Sep 2012
    Oakley, CA
    Come to think of it, this problem didn't start until I got my Cal-Sci windscreen. I love the windscreen and would rather take the antenna off entirely than go back to the stock one. I've ordered a cheap replacement antenna off Amazon and we'll see if it works.
    Nate R
    Apr 2014
    Central Coast, CA
    Makes sense, thanks.
    Albuquerque, NM
    Kent Christensen
    21482
    Sep 2012
    Oakley, CA
    Thanks Kent. I ended up ordering from your link to ECS Tuning. I got the 120mm billet antenna and it looks nice and is much more sturdy than the stock one. Seems like a must if you have an aftermarket windscreen that directs more wind onto the antenna.
    Here are a couple pics:
    Nate R
    Albuquerque, NM
    Looks really good!
    Kent Christensen
    21482
    Dec 2011
    Menlo Park, CA
    Looks really good!
    But how well does it work?
    JayJay
    '09 R1200 RT
    Lots of rice burners in the past ...
