Results 1 to 3 of 3
Thread: 2002 K1200RS - engine revs unexpectedly
    Feb 2008
    Would an intake air leak cause the engine to rev up without throttle input? Where the leak need occur - before an airflow sensor? I'm trying to understand how a leak might cause my engine to rev
    Thanks for any input
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    Air leak
    Spray a little WD-40 around the throttle bodies and connections to the intake manifold. Any change in RPM will be a clue.
    It's not very sophisticated but a simple place to start.
    1986 K75S(the beutch), 1993 K1100RS (blown engine), 1997 Chev Short Box (4x4 with an LT1)
    "Life isn't about how fast or how high, it's about how well you bounce."
    Oct 2003
    "Big Bend" TX
    On your bike (and almost all internal combustion engines) the engine speed is throttle controlled. That is, a throttle plate "throttles" or restricts air flow into the cylinder(s). When you open the throttle the engine speeds up. If you have an air leak that is after the throttle plate in a carburetor or throttle body then the cylinder is getting more air than intended and the rpm will be higher. This is generally noticed as a high idle speed.
