Results 1 to 9 of 9
Thread: ABS Blues '08 R1200RT
    Add me to the number of unlucky souls who have had their ABS module bite the dust. I'm attempting to remove the offending unit from my bike, 2008 R1200RT, and send it off for
    repair. My question is this, have any of you removed the ABS unit from your bikes? If so, can you give me any pointers on extraction? I've removed the plastic, and gas tank
    but am still puzzled as to the removal of this thing. I'm trying not to remove any more parts than necessary, but i'm starting to think that the ABS module holds the entire machine together.
    Thanks for any input, Al
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    What bike? What year?
    Nov 2011
    Central Ohio
    Quote Originally Posted by pretzelstick View Post
    'tis a mystery, indeed.
    Larry
    2006 R1200RT
    AZ
    A couple of sharp hammer blows to rear of the ABS motor will re-seat the motor brushes. I did that 4000 miles ago... still working.
    MOA #107139
    RA #28511
    YB #2005
    Jun 2008
    SF Bay Area
    The OP must have edited that later ... after all I couldn't be that blind.
    Remove the tank. Drain front and rear brakes. Remove air snorkel if you didn't, already. Disconnect the brake lines from the pressure modulator. Disconnect the electrical connection. Remove the screws that holds the bracket to the bike. The modulator comes out attached to its bracket, then you remove the bracket.
    I helped someone do that much. The job wasn't hard. Some cable ties had to be clipped that attached cables to the bracket before the bracket/modulator could be removed.. I wasn't around when he put the unit back and can't comment on that.
    Still Blue
    Thanks Marchyman for the response, I'll psyche myself up for another go at her tonight! Azgman, I liked the simplicity of the hammer approach, I'll use it if I can't get this thing out.
    It doesn't lift my spirits to see consumer reports just proclaimed BMW the most unreliable bike on the road.
    Al Scortino, Sebastian, Fl
    Current Ride 08 R1200RT
    Thanks again for the help! ABS module has successfully been removed and is going out today for repair.
    This forum is a great resource!
    Registered User hrvatin's Avatar
    Jan 2008
    Salem, Ohio
    How was the re-install? My ABS module is coming out soon to send to be re-built, and am wondering about the installation/bleeding when I get it back.
    Any comments would be appreciated.
    Ron
    Hrvatin
    Northeast Ohio
    2008 R1200RT
    1984 R65
    ABS adventure
    Quote Originally Posted by hrvatin View Post
    Ron
    Ron, It actually went in easier than it came out. If you extract and re-install it from the left side of the bike, using a good dose of patience and tenderness you'll be fine. Once all the lines are connected it's just a matter of doing a basic bleed job front and rear and re-installing all the body work.
    Good Luck, Al
