Results 1 to 4 of 4
Thread: Pre-installed GPS/wiring question
    Novice Adventurer Newstar's Avatar
    Landenberg, PA
    I have a friend who's wife is trying to help him be able to use the MP3 player on his BMW motorrad GPS with earbuds. She asked me for help since I use my 660 with earbuds. I use the aux output jack from the octopus wiring harness or the actual jack on the side of the unit. Problem with helping her is the cradle for the BMW GPS covers the jacks on the side of the unit and i have no idea what the original harness looks like since it was dealer installed. Anyone know if the wiring harness for the BMW unit has the output jack or is their another way to use earbuds with this unit without a lot of re-wiring?
    Landenberg, PA
    Anyone??? Beuller????
    Debbie's Servant Lee's Avatar
    SW Iowa
    Quote Originally Posted by Newstar View Post
    I thought you could only listen to a BMW unit through Bluetooth ????
    Lee 2011 K1300S
    MOA # 30878
    Registered User Lisa_ST's Avatar
    Jun 2004
    Phoenix, AZ
    The only ways I know that WORK to do this are to use bluetooth or to use a device like an Autocom which would also ultimately use bluetooth.
    You could probably REPLACE the BMW cradle with a generic Garmin one and then you would have access to the audio out port. I don't know if you lose functionality in that case. If you have questions about the Autocom solution, email me off forum at lisa@autocomdirect.com
    Lisa Malachowsky
    2014 R1200GSW-low
    tripgrrl@gmail.com
    www.divenrideadventures.com
