Results 1 to 5 of 5
Thread: "Repair" plug power for GPS- '05 R1200RT
    Rider Neil
    Aug 2005
    Brighton, Ont
    I cannot get power to the gps through the cradle mount for the Garmin 660 I am installing on my 2005 R1200RT. I am using the BMW "repair" plug and, while I am getting power there, it doesn't show power to any of the pins on the cradle when tested. Any suggestions?
    Outlander Omega Man's Avatar
    Mansfield,MA
    I think I've seen where a hook-up of this method didn't go well due to a forgotten ground wire- don't know if this is your case. I'm more of a fan of the direct wire approach. This is almost a "Gear" kind of question so if it doesn't get you a better response, I'll move it for you. I'll fix your title so it will be a bit easier for a member scanning through to give you some help.
    Good luck, Gary
    2009 F800GS 1994 TW200
    Part of the Forum Threadside Assistance Program
    Nuckin' Futs! tonyfr's Avatar
    Apr 2007
    SAT - LAX
    If you have 12V power to the plug and your GPS is wired power and ground, could be a bad cradle. How old is the cradle for the GPS? I have an 05 R1200RT also and I run my power for the 660 from the parking light bulb.
    SABMWRA MOA #62
    2005 BMW R1200RT
    2008 Honda CBR1000RR LE
    1984 Kawasaki 750 Turbo E1
    Apr 2012
    Los Angeles, CA
    Just a thought, as I don't have one of these cradles - but is it supposed to have a hot pin when there's no unit attached? Since the pins are exposed to the weather, it'd make sense for them to be disconnected until mated to a GPS, presumably completing the water-resistant seal.
    2000 R1100RT / 1987 K75C (RIP) / Santa Clarita, CA
    Rider Neil
    Aug 2005
    Brighton, Ont
    Thanks for you input. I think I found the problem but do not know why what I did appears to have created the problem.
    I clipped off the in-line fuse on the original and replacement harness which Garmin sent me because they should not be necessary with the Canbus system. At a club meeting someone mentioned that the GPS should come on when the power comes on even though the GPS is not turned on. Garmin, by mistake, sent me another replacement harness. On receipt, I put the GPS in the cradle and touched the battery terminals....it came on!!!! Next I soldered the removed in-line fuses back on the other two harnesses, and, when touched to the battery, they both came on.
    I do not know why the removal of the in-line fuse should matter, but everything seems to be OK now and I think I now have two good back-up harnesses.
