Results 1 to 7 of 7
Thread: 1987 K100RS- Rear Master Cylinder Rebuild Kit
    On the Road
    Dec 2012
    Akron, OH
    My rear master cylinder is losing a few drops of brake fluid each day, and my rear brake could definitely be more powerful. I was curious to know if anyone had used the rebuild kit that is available for these bikes. If so, how were the results?
    Additionally, I see that there are 2 kits available: 12mm Magura and 13mm Magura. Can someone tell me which one would be the correct fitment for my 1987 K100RS?
    Thanks!
    Belton Tx
    Look on the body of the cylinder for the size. You may have to remove the cylinder to see the marking.
    Ron
    91 K75RT ABS
    IIRC - the size is marked in a circle. You probably have the 12mm if your bike has ABS. Using www.realoem.com with your VIN# should give you the correct part number.
    As far as your other question.. it depends.
    IF the brake fluid has been changed on schedule (every 24 months from date the bike was manufactured) it's possible your cylinder is still in good shape. Cleaning it up with some 1,000 grit paper (with brake fluid on the paper), then cleaning it up carefully might make it a good candidate for rebuilding.
    IF the fluid hasn't been changed regularly - the cylinder is the lowest point in the rear brake system, and moisture will accumulate in the cylinder causing corrosion. Fixing that is beyond the scope of a cleanup. The corrosion usually leaves pits in the cylinder which will quickly destroy a new seal resulting in the same (or worse) leaking you now have. On a bike that the cylinders aren't available anymore, there are speciality shops (catering mostly to classic cars) that will bore the cylinder and fit a brass lining to it, but that's not cheap, and would likely cost more (with the rebuild kit) than a brand new cylinder.
    SW Ohio
    Yours should be a 13mm, they didn't have ABS in 87, did they? this is from beemerboneyard.com
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Registered User robsara's Avatar
    Dec 2009
    West Michigan
    FWIW, after I bought my K75, before I had my cycle endorsement, my rear MC was leaking. I asked about it where I bought my bike. The BMW dealer said they would fix it. They said there was a rebuild kit available, but didn't recommend it. They instead recomended a new MC.
    Since it was their dime, I let them fix it their way.
    I'm sure you will have other opinions, but I thought I'd take the time.
    Rob R
    1994 K75 My first bike.
    Registered User beemerguru's Avatar
    Foster City, CA
    On the bottom of the MC is the number 12 or 13. Still available from BMW.
    You have a 50/50 chance of success on a rebuild. Easier and safer to get a new one. Might check the hoses for age issues as well.
    Greg Hutchinson
    R80G/S (4) 633CSi with 450K mile
    '68 R60/2 '88 K100RS Special Edition
    http://gregsgssite.shutterfly.com/
    Beemerboneyard has complete new master cylinders for $129.
    On K100s, 13mm was used to 10/88. 12mm after 12/88.
