Results 1 to 4 of 4
Thread: 1987 K100LT Throttle positioning switch
    Sep 2009
    North Branch, Minnesota
    How do you test the TPS?
    I hear it click but how do i know the click is making something happen?
    Bike runs great but I smell fuel in the exhaust when I start it up cold.
    Thanks,
    Tim
    Belton Tx
    The TPS has nothing to do with the smell. My 91 K75Rt smells the same. I think the reason is that our JETRONIC? systems are not as advanced as the later MOTRONIC? systems.
    Ron
    91 K75RT ABS
    Apr 2012
    Los Angeles, CA
    If your TPS is broken, your bike will routinely backfire when you close the throttle and engine brake for 5-10 seconds, as when descending a hill.
    If you want to test this, you can unplug the TPS and try some engine braking. In normal riding, the bike runs just fine without the TPS; some say better.
    You can also check the TPS by unplugging the cable and using an ohmmeter to check continuity between the middle pin and the outer pins. One of the outer pins will show continuity with the throttle closed, the other with the throttle fully open. (I don't remember which is which.)
    2000 R1100RT / 1987 K75C (RIP) / Santa Clarita, CA
    Sep 2009
    Quote Originally Posted by JamesInCA View Post
    Thanks for the information
