Results 1 to 5 of 5
Thread: '86 K75C How do I remove instrument face?
    On the Road
    Jul 2006
    Mckinleyville, CA
    '86 K75C I need to remove the gauge cover (shell) to flatten tach face. There are two screws on the back of the case and the trip meter knob. Will the two screws release the gauge cover and give me access to the gauge faces? Also, how do I release the trip meter knob to pull the gauge shell?
    Thanks,
    The trip meter knob is spring loaded. It needs to be pulled out about 3/8" to disengage it from the trip meter shaft.
    First remove the 9 screws around the perimeter of the back cover (don't forget the one at the bottom of the connector pins). Do not remove the two screws in between the mounting holes. Remove rear cover. I don't remember if there are a couple of screws around the perimeter inside the cover that hold the guts into the front housing or if it's just the knob. All the guts come out in one piece.
    On the Road
    Jul 2006
    Mckinleyville, CA
    OK I got the guts out of the housing. The tach face is badly warped and interferes with the tack needle. I would like to try to flatten the face but I need to remove it first. So, I also have to remove the tach needle. How do I release the needle?
    Thanks much,
    I BELIEVE it is just pressed on to the shaft. Use two screw drivers to carefully pry up.
    But, i could be wrong.
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    Agreed- press fit to the shaft.
    Ken
    IBA #44567
    -Albert Eienstein
