Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
Thread: Oil Filter Wrench
    Jul 2013
    Oil Filter Wrench
    What size oil filter wrench does a 1997 R1100GS use?
    Left Coast Rider
    Vancouver Canada
    It's the same size as many Mercedes and VW and you ought to be able to find one for $10. For sure you do not have to use motorcycle sources.
    It's 74 mm, 14 flats.
    Apr 2012
    Los Angeles, CA
    lkchris is correct, but I'll add a couple of thoughts. On my K75, the most commonly available plastic one wouldn't fit into the filter cavity, even though it was correctly sized for the filter. A second inexpensive metal one fit fine, but wouldn't grip the filter tightly enough. (On the K75, the filter hangs in the oil bath, so the canister is very slippery.) It was finally the BMW OEM wrench that gave me complete satisfaction.
    2000 R1100RT / 1987 K75C (RIP) / Santa Clarita, CA
    Jun 2012
    I know I'm going to get reemed for this.
    And, It might not be the thing to do on a GS.
    I use an automotive filter. If I can find it I use a PureOne PL25230.
    It is about 1.5" taller, and sticks out from the bottom of the sump so I can get it with a conventional small filter wrench.
    Usually I don't even need a wrench, since it has the grippy coating on the end.
    Do not put one of these in a K bike inside the oil bath. The grippy stuff will loosen and come off in your oil eventually.
    Exterior applications only.
    Jun 2012
    You can shoot a couple of self drilling metal screws through the wrench into the bottom of the filter.
    Apr 2012
    Los Angeles, CA
    Quote Originally Posted by GKman View Post
    I resorted to something like this to get my first filter out, which had apparently been installed by a gorilla. After that, I was very happy to have a wrench that just worked right.
    Quote Originally Posted by scott.lambert View Post
    The OE filter has a bypass valve. You can see it. Does your "automotive" filter? Suppose it's set for the same pressure? Did you look up the specs?
    Jun 2012
    yeah, see, here we go...
    yes
    yes
    no
    yes
    it also has an anti-drainback valve.
    I know. But, it's fine, really.
    RD'nNH&AZ rdhudson's Avatar
    Apr 2012
    I gotta read more carefully
    I thought it said "Oil Filter Wench" so I felt the $38 for the nice lady's service price was fine. Now that I see it says wRench and I gotta do it myself I'll check it out at wally world. Perhaps take my spare filter in to get a good fit?
    Canada and the Alps
    Possibly 76 mm?
    Its also used on Porsche oil filters OC 213 and OC 229.
    74.5 actually
    Apr 2012
    Los Angeles, CA
    I know oil threads can go on for ages, but who'd have thought "what size oil filter wrench" could start such discussion?
    Since I happen to have two old filters and three wrenches handy, I took some measurements. All are mm across flats.
    Filters mm
    Purolator L10241 72.3
    Bosch D3330 72.4
    Wrenches
    Stamped metal 74.3
    Plastic - size "D" 74.2
    Hazet (BMW) 74.5
    Mar 2013
    Winnipeg, MB, Canada
    Umnnn, BMW doesn't make filters. They aren't proprietary. Just in case you didn't know, BMW doesn't have it's own oil refinery either. I use Wix 57936 which are the OE for BMW. They cost me about $8.00 CDN by the case. On any given day it's 27 cents USAD or $12.00 USAD? The filter wrench is off the shelf and fits pretty good. If filter bypass is a concern, I would suggest knowing a good engine builder and fast.
    Just to mess things up, the only K&N on my R1100RT is the air filter. In think the story I have about my K&N oil filter is pretty common.
    I really like the comment about the PureOne PL25230. An extra inch would be awesome when you leave the filter on while the bike sits for six months, like in Canada.
    "Life isn't about how fast or how high, it's about how well you bounce."
    Canada and the Alps
    Quote Originally Posted by Dieselyoda View Post
    Thats news to me.
    The BMW oil filters I buy at the dealer are Made in Austria and are 100% identical to the Mahle OC 91, which are Made in Austria.
