Results 1 to 7 of 7
Thread: 1996 K1100RS leaking oil
    Moondog
    Savannah, GA
    Coming from seep hole (can u say rear
    main seal?). Does the multitude of riders
    think over filling with oil can cause it to
    "over flow" through the seal? I had to drain
    a cup and some to see the level in sight
    glass
    Wilmington, NC
    Well a cup over isn't likely to trigger a seal leak- IF that's what it is. Any chance its dripping from elsewhere?
    Overfilling the oil in most engines can cause problems, that's why there is a full mark on a dipstick or sight glass. When overfull, the crank throws will dip into the oil causing airation of the oil and increasing the oil temperature and crankcase pressure. None of those are good for an engine. In some cases, the increasesd crankcase pressure can cause seal leaks. Also some power will be lost.
    Maybe you will get lucky just by returning the level to the correct height , maybe not.
    Why was it over filled???
    Moondog
    Savannah, GA
    Aliens invaded my garage overnight, read my maintenance manual for the proper oil, found some on my shelf and filled her up.
    I really don't need to answer that question do I?
    Here's your sign....
    You must forget that the possibilities include dealers and service shops.
    You imply that YOU over filled the oil, then YOU did not check the sight glass, then YOU rode it that way??
    The sign, my friend, must belong to you.
    Moondog
    Savannah, GA
    Long story....and guilty as charged. Luckily it wasn't more than it was. My comment was being facetious and a clown. No offense meant.
    Moondog
    Savannah, GA
    No, leaking from seep hole. I just finished putting trany back on so drive shaft may have had something to do with it. A whole new level of maintenance for me so I am pleading no contest...
    And then again I am fixing stuff from a mechanic in Florida, who I find out after the fact says "that he hates working on K-bikes" (not me). Not many miles on it since then so who knows. It is now filed as a project on my to-do list.
