Results 16 to 19 of 19
Thread: Accessing coolant expansion tank area/removal of plastic panel
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Jun 2008
    SF Bay Area
    Hmmm. I got the shrouds off -- part of my "where will I put all the wiring" project. When I pushed on the center it went flying. It took a few minutes but I eventually found it. I was ready for a flying pin when I did the other side... that only meant it didn't fly as far. The center parts on mine don't look or feel like they want to be inserted from the front. I will try to insert from the back until it comes out the front when I get around to re-installing the shroud.
    Is that what you guys had to do?
    In all other respect the plastic (including the beak) comes off pretty easy. Just way too many pieces/screws. The '05 spoiled me.
    Registered User Emoto's Avatar
    Jul 2003
    Boston
    Yeah, the quarter turn fasteners on the 05s were great. As long as you got that lower front inside one set right.
    I haven't dislodged the special plastic one yet, but may do this weekend, if I get around to it.
    Eventual Master of the Obvious
    SE Mass - SOHC4 - DoD - BMWMOA - EMOTO #1
    ...proud walking jingle in the midnight sun...
    Free Smugmug Discount Coupon: mStnWv71mNkjo
    Oct 2013
    When I had the side panel off I highlighted the fill level lines with a sharpie marker so that I could see the lines through the view slot. I did the same on the fF650gs too. It is just convenient.
