Results 1 to 13 of 13
Thread: LED panel lights - '03 K1200RS
    Apr 2007
    SE PA
    At least one, and maybe two, lights have gone out on the gauges for my '03 K1200RS. Since I have to pull the tupperware to replace them, I might as well look into LED's for all 16(!) lamps. The part number is 62142306126 - 12V 3W T10 base. The big question is light output. I can find suitable LED's in a range of outputs (in lumens). Darned if I can find out what the rating is for the BMW bulb. Has anyone switched to LED's recently (I understand older conversions weren't all that reliable)? What brightness did you use and would you go brighter or dimmer?
    Don't let your bike go anywhere your brain hasn't already been five seconds ago...
    Apr 2007
    SE PA
    Bump
    Nobody has tried LED's behind the instrument panel?
    Ohio
    I have blue LEDs in mine. Put them in years ago. Have no idea of p/n or output. I would go brighter.
    Jeff
    93 K1100LT
    03 K1200GT
    Jan 2009
    Hillsborough NC
    I have seen examples but nothing about the info you requested
    Red ones made it easier on night vision, you just loose the distinction between the red warning areas of gauges and the white areas. I have seen images of the standard white lights giving the dash a nice crisp blue/white glow, although a bit bright. (I typically have my dash lights in cars pretty mid to slightly less than mid brightness).
    There were some examples of this I remember on I-BMW with images.
    Let me know what you do and show the results. I have several out also around the time/gear indicator area.
    NCS
    03 K 1200RS (Black is Best)
    03 Honda RC51
    74 Honda CB750 K4
    Jun 2007
    I am pretty sure I saved a link to someone's discussion of this, along with pics, supplier, exact bulb (range of colors) and all. That was on one of the other forums and on my computer at the Inn. I will try to remember to look it up later today and post it if I can find it. It is something I Need to do as well.
    Jim Douglas '00 K1200RS >135,000 miles my primary bike again,
    '06 Kaw 650R track bike sold
    http://www.seagullbb.com/
    Apr 2007
    SE PA
    Thanks for the replies - this moves me in the right direction. I have red LED's in my VW Vanagon - yep, the red no-go areas in the gauges are hard to find. NTL, I kind know where "too fast" is on the tach and "too hot" is on the temp gauge, so it's not a big loss. I've been going back and forth between blue (v. cool look) and red (matches the paint!). Ah, decisions, decisions...
    Mar 2007
    Chicago, Ill
    I put these into my 85 K100RS
    Apr 2007
    SE PA
    Thanks - email sent!
    Dec 2008
    Belle Plaine, MN
    I swapped out the backlight and other bulbs in the instrument cluster on my 85 K100 RT with LEDs from http://www.superbrightleds.com/
    They have a large selection and will probably have what you need.
    Apr 2007
    SE PA
    Their 194 bulb seems to be the contender. Now if I can only nail down how bright they are compared to the incandescent lamps...
    K75RT Keith
    Apr 2011
    Rocky River Ohio
    Put LEDs in myK75RT and have been very pleased with the results. kbikeparts.com may have a set for your bike.
    Apr 2007
    SE PA
    I'm waiting on a reply from KBikeparts.
    Dec 2008
    Belle Plaine, MN
    Just for reference I looked up my parts list for the exchange on my 85 K100RT. Here's the list and a photo of the results. Sorry I didn't take a "before" picture for reference.
    LEDs purchased from: http://www.superbrightleds.com
    Indicators: WLED-x-x (194 style) - 9 @ 1.39/ea
    Backlights: WLED-x4 (194 style/Green) - 5 @ 2.59/ea
    Turn Signals: BA9s-x-x-12 Wide (BA9 style) - 2 @ 1.98/ea
