Results 16 to 19 of 19
Thread: 1978 R100S, Odd noise from right cylinder head
    Pismo Beach, CA
    I'll try that. I just figgered that the braiding would keep the rubber for disintegrating; may the braiding is what's causing the abrasion (?)
    Lew Morris
    1973 R75/5 - original owner
    Monza Blue 1974 R90/6
    Delaware
    In my case, with the tension of the curved choke cable pressing against the back of the petcock, the internal metal casing of the choke cable first vibrated it's way through the plastic outer cover of the choke cable and then metal to metal, started chewing it's way into the petcock. The spiral steel winding makes a great saw.
    Barron
    Jan 2013
    Iowa
    Hope everyone had a great Memorial Day weekend- I meant to post this sooner but between Memorial day and other happenings...
    Anyway, heres what I found in my case: Red arrow is where fuel tank seam was rubbing on the right horn strap bolt.
    My Dad recently borrowed my uncles 1978 R100/7. Both his bike and my '78 R100S have exact same Luftmeister fairing setup, so I was comparing mounting positions. What I found raised another question for me- the R100/7 does not have the spacer(indicated by blue arrow) and its horn straps are aimed downward(simulated by yellow arrow) and horns positioned appropriately. As a result the strap and bolt are much further in and nowhere near rubbing on the tank like mine is. Also, with this setup the horn straps are also rubbing on the frame. At this point I'm thinking I'll remove the spacers and get shorter bolts and re-aim the horn mount straps like they are on my uncles /7.
    Is this spacer part of the stock R100S fairing setup?
    1978 R100S Smoke Red Metallic
    So you have a full Luftmeister fairing on the R100S as opposed to any smaller bikini fairing? I have a Luftmeister on my /7 and don't think I have any kind of mounting bolt like that. The picture is a bit close in to tell exactly where you're looking. The fairing sits as a shell sits on top of a metal frame, held to the metal frame by two small bolts on either side. The fairing frame is held to the bike's frame by a set of hose clamps, one each on the forward frame downtube and one clamp on the cross member between the two downtubes. I have dual Fiamm horns which IIRC are connected to welded eyes on either side of the frame. I have a metal bar that connects on one end to the eye and the horn attaches to the other end of the bar. I think the bar does two things...extends the horn away from the frame and also provides for something to vibrate when the horn is use...I think the horn sound/vibration couples with the resonance of the metal bar.
