Results 1 to 11 of 11
Thread: 2004 R1150RTP - noise on deceleration, what is it?
    Registered User Badger7's Avatar
    Mar 2009
    Middleton, WI
    I'm soliciting your help to diagnose an engine noise on my 2004 R1150RTP with 110k. The engine runs great and smooth, but when using engine braking (decelerating with clutch engaged) the engine makes way too much rattling.
    I thought it would be the cam chain tensioner, but reading more on the "is this the dreaded death rattle" thread, it doesn't sound like that's it.
    I know I should just run it to the dealer for diagnosis, but my nearest one isn't very "near". And I'm wondering if I'm going to damage it by driving it there?
    Your input is appreciated.
    what kind of rpms are you running at that point?
    have you looked at tightness of all exhaust connections?
    Jun 2012
    Probably just valve clatter. How long since your valve lash was adjusted?
    It's not the so-called death rattle of the left-side cam chain - I think they fixed that in the 1150 anyway. That only occurs at startup. And it is pretty much harmless, unless someone is there to hear it and say something that hurts your feelings.
    Perhaps it is making the rattle full-time and you can hear it when the throttle is closed because the intake and exhaust noise drops away?
    Sometimes I can adjust my windshield to a point where the motor noises are reflected back to me - might try that.
    Anyway the main thing that happens when you slam the throttle shut at relatively high rpms is that there is a dramatic decrease in the cylinder pressure. Also the throttle position sensor is now "lying" in that it says throttle is closed, minimal air flow, while in reality more air than that is actually being dragged in. So the ECM backs down the fuel - the result is a lean mixture that is not compressed properly, you get backfiring and that sort of thing. fixed as soon as you open the throttle again.
    Um, most likely thing to be rattling are the things with some rattle "required" - that's the valve rocker arms.
    At 110k there may be some wear on your actual valves. Sometimes this results in more lash, sometimes it results in less lash. More lash is a rattle, less lash usually results in the engine misbehaving when hot, if the valves don't close all the way.
    The valve clatter, particularly if the lash is too large, will have a resonant frequency, like any other thing in repetitive motion. So there will be an RPM value where the clatter is louder than anywhere else.
    Is too much lash harmful? - I don't think it is but I'm not sure.
    The sound is created by pieces of steel slamming together rapidly, which my primitive brain thinks is not good. But then, aren't they slamming together anyway? - just not bouncing around maybe.
    Excessive lash will change the valve timing slightly. They stay closed longer. Whether this is a good thing or a bad thing depends on too many variables for me.
    No longer a member here
    Clutch rattle.
    Jun 2012
    Quote Originally Posted by EMSimon View Post
    Clutch rattle.
    ??? hmm.
    Obviously I'm missing out, haven't experienced this.
    Of course I'm only at 80k.
    The R1150RT, like many BMWs, has an automotive-type, single plate dry clutch with torsion dampers (small springs) in the friction plate. If one (or more of them) brake, they cause a rattle in the drive train during load changes.
    Jun 2012
    I think you could ride it to the dealership.
    check your throttle body shaft for play. (do a search on it to find correct procedure)
    Feb 2006
    Long gone
    Load changes occur on both deceleration and acceleration. Shouldn't it be heard when he accelerates or does engine noise mask the rattle??
    I used to post here, but now I don't.
    Jun 2012
    Badger7, are you aware there is a BMW shop in Beaver Dam?
    http://www.mischlersbmw.com/
    Closer than Milwaukee, at any rate.
    Mar 2009
    Middleton, WI
    Update- transmission (not engine)
    Thanks for all your input.
    The noise seems to be the transmission, and might be the clutch plate as suggested. I wouldn't consider it "normal" sound though. (I have a 1994 R1100RS, and it has never sounded like this.) The deceleration noise doesn't seem RPM related, but it was around 3500-ish when I was hearing it. I checked the throttle body shaft and valve clearances, and those seem fine.
    When at idle on the centerstand, in neutral, there is some (slight) rattle noise, which goes away when the clutch is pulled in. This is in addition to the deceleration noise.
    Yes, I will have to run it up to Mischler's. My other nearest BMW specific option is Boxer Rebellion, if Norm has time for any projects.
    I'll be sure to update the thread again with updates.
    Thanks again.
