Results 1 to 15 of 20
Thread: Valve adjustment?
    Oct 2010
    East central, WI
    Valve adjustment?
    I don't have one but can someone tell me the procedure for adjusting the valves on the new engine? A condensed version would be fine. Just wondering and haven't seen it published. Thanks much.
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    I think you have to remove the cams to get at the shims (adjusting plates according to the parts breakdown), but that is guesswork from looking at the engine pics.
    kindofblue reidhester's Avatar
    Jun 2012
    Albuquerque NM
    Thumbs up Valve checks q 12k mi.
    Valve checks are every 12,000 mi. Here's a link to a google doc from advrider.com to the service schedule
    https://docs.google.com/file/d/0B9Dh...1zZWZLc3M/edit
    I'm not sure whether non-google users can access this though.
    Valves may well never have to be adjusted though because of the new design. The same seems to be true of the camhead GSs (08-12).
    And because it's fly by wire, there's no more throttle body adjustments!
    Warmest regards,
    Doc Reid Hester
    Wondering about your drinking? Consider our FREE Drinker's Checkup
    Get saddlesore when riding? Check these shorts out
    Oct 2010
    East central, WI
    Thanks and its great if it never had to be done - but - what if it did? Remove head covers, cams and insert shims???
    Jun 2008
    SF Bay Area
    Remove valve cover. Measure. If out of spec calculate the needed change(s). Remove cam (that part is a guess) and remove current shim(s). Measure the shim(s) (maybe it's the marked size, maybe not -- assuming the shim is marked). Add in the calculated adjustment. Match that to the nearest standard size replacement shim. Buy (order) needed shims from your dealer. Replace old shim with new. Restore cam (assuming it was removed). Measure again to make sure you didn't screw up a calculation. Restore valve cover.
    Easy.
    Jun 2009
    Just like the valve adjustment on a flying brick 4 valve K bike.
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    So the question remains unanswered. I've asked a few people, including a new owner, and nobody seems to really know "fer sure" yet...
    Shims? And what style? Setscrew & locknut? Slide the fingers over?
    Whoever gets inside - post a picture!!!
    "Never" is a pretty long time, very hard to accept... even hydraulic lifters may need a check once in awhile, especially if the oil is low-grade or not changed often enough...
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    From pictures, it looks a lot like a camhead. It has overhead cams with rockers and I imagine it uses shims.
    I've never had to check hydraulic lifters, not without having to replace them.
    My Motorrad
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
    Agreed, hydraulics are typically super-reliable and people take them for granted (in cars) and mostly ignore them.
    Their installation usually requires a specific "preload", maybe two turns of "compression" after the initial touch of the mating parts. If this isn't done correctly (and it's really not so very critical in a non-racing engine), it may wear faster or cause faster wear of the cam or followers, especially if the case-hardening was thin to begin with.
    Stock Harley hydraulic lifters got a bad rap for a long time because they'd collapse and spew bearing needles through the engine - very expensive if not caught immediately. ("What's that awful racket? I'll just spin it more and see if it quits.") Valve control improved when solid rods were installed, since they didn't need to spin up too high; occasional lash checks were accepted as the trade-off.
    Honda's Hawk 750 needed high-quality oil & frequent oil changes to keep the lifters reliable; otherwise it was a great motor.
    Dec 2010
    Fountain Hills AZ
    The Vulcan 1500/1600/1700/2000 have hydraulic lash and without drama.
    My Motorrad
    Good examples of how to do it, though they certainly don't spin like our engines.
    I haven't kept up with Kawi's developments; do their hydraulic valve trains live a long time?
    I've also expected Suzuki to come out with a good system, since they have a reputation of their bikes absorbing a beating and keeps on ticking.
    What do the big Yamaha Vees use?
    Dec 2010
    Fountain Hills AZ
    Quinton Grubbs did 260k miles on his 1500 nomad and I know another guy with a 2009 1700 voyager that has 175k miles. Lots of folks go over 100k miles with 1500/1600 nomads.
    My Motorrad
    Dec 2010
    Fountain Hills AZ
    Big twin Harley's don't rev higher than vulcans
    My Motorrad
    Thanks, Kent! Now, do the followers slide sideways or does the cam have to be pulled...
