Results 1 to 6 of 6
Thread: Devilish stalling problem 2007 F800ST
    The Big Red One sgtbill's Avatar
    Jul 2006
    Herndon, VA
    My dear wife bought a used F800ST a few years back. Almost immediately she mentioned it would stall when she was down shifting as she rode toward a traffic light that had changed to red. The stalling would not appear until she had been riding for more than an hour or so. We have had the bike in to have the problem fixed several times over the past few years. We have replaced a hose that sometimes collapses causing stalling and it still stalls. We have had injector cleaner run through the engine and it still stalls. Recently the problem has become more acute in that the bike stalls more frequently as you ride. And gets harder to restart after a stall. A couple of weeks ago it was at the dealer and they diagnosed a crankshaft sensor malfunction so that was replaced and it still stalls. The next attempt was to remove the canister attached to the fuel tank relief hose and it still stalls. I rode the bike this morning to see if the canister removal improved things. After 2 hours of riding and about 100 miles it stalled at a stop sign and continued to stall for the next hour until I made it home. One new symptom appears to be an electrical hiccup. Twice while attempting restart the instruments turn off completely. Just like the key was turned off. It only lasts about 3 to 5 seconds before it reinitiates (the speedo and tach flip all the way to the right) and then I was able to restart. But it kept stalling. I'm not sure the electrical symptom is related or just a mean-spirited coincidence. Anyone have any ideas?
    I've read several threads on the stalling problem and don't see a common cause to any of them. We're quite frustrated by this and will probably trade the bike back to the dealer in the next few months. We were thinking of a F800GS or the F800GT but are concerned there may be stalling issues with any F800.
    sgtbill
    Duty First!
    86 K100RS EML & 79 R100S
    2007 F800ST & 2014 F800GS & 2014 F700GS
    I suspect it might have a faulty engine temperature sensor. Voni's F800S did this on very hot days until the sensor was replaced. Just a guess, but ...
    no thoughts on the problem, but my in 30K miles, my F8GS only had a stalling issue prior to it's getting the canister recall done. but that was only 1 or 2 times, only in the rain.
    Jul 2006
    Herndon, VA
    Gonna take it to the dealer
    And try to get them to force the software update. I'll have my wife let them know to check the engine temp sensor as well. I'll let you know what happens then.
    sgtbill
    Duty First!
    Jul 2006
    Herndon, VA
    Dang that software anyway
    Karla's bike went back to the dealer after they found the stalling cause with a GS-911 fault with the crankshaft sensor. Replaced that and it still stalled after 90 minutes of riding. Hard to get the dealer to test ride something that long. On Wednesday they took it back and issued Karla a loaner F800S. First a check of battery and fuel delivery then finally a check of firmware. Guess what, never been updated. A force of the update and the maintenance super rode it home that night. On Friday we picked it up and for the first time in several years it ran flawlessly for the weekend. Three days in a row of + 6 hour riding days without a flinch. What a relief. Our plan is to give this bike to our daughter next year after several different rider training courses.... Can't do that if it is stalling. On the good side the maintenance outfit didn't charge us for the additional tinkering required to get to the solution which avoided a head-butting contest I'm sure neither of us would have enjoyed.
    sgtbill
    Duty First!
    Apr 2013
    engine temp sensor
    Paul, did you replace the water temp sensor or the air temp sensor. also, do you use any sealer on the valve cover gasket?
    thanks, John
