Results 1 to 3 of 3
Thread: False tire pressure warning
    Aug 2011
    Here's the background I've been riding at highway speeds for about an hour. The yellow triangle caution light comes on on the left side of my instrument cluster. Almost immediately a second yellow caution triangle lights up next to my front tire monitor on the computer screen.
    I pulled over shut down and inspected both the front and rear tire. Finding no nails or cuts I got out my tire pressure gauge and found I had 2.5 Bars in the front and 2.8 in the rear.
    On restart I had no readings for either front or back even after travelling down the road. I road home and rechecked the air pressure with my digital reader and got the same results.
    An hour later everything was back to normal with the front display coming on upon start up and the rear after travelling a short distance.
    What happened?
    Do the sending units in the tire run on battery (watch size) and could they be due to be replaced. The bike is a 2008 F650GS Twin.
    Registered User middleagecrazy's Avatar
    Mar 2012
    Joliet, IL
    Hi Romany. I have the same problem with my 2007 F800st. The dealer said it's best to replace both units when the sensors go off and there is nothing wrong. I was told the batteries are sealed in the sensor unit. If you know everything is o.k. as far as tire pressure then the best thing to do is replace the sensors when you replace your tires....Just keep track of your tire pressure in the mean time. I just ordered new sensors from Bike Bandit and it cost me just under $245.00
    Aug 2011
    Quote Originally Posted by middleagecrazy View Post
    Hi Romany. ... replace the sensors when you replace your tires....Just keep track of your tire pressure in the mean time. I just ordered new sensors from Bike Bandit and it cost me just under $245.00
    That's good advice. I think my current tires will last out the summer and fall. I've now got my digital tire pressure gauge in the on bike tool kit.
