Results 1 to 13 of 13
Thread: '98 R1100RT Side Stand Shut Off No Longer Working
    RK Ryder
    London, Ontario
    Is there a simply fix for this problem?
    Thanks in advance.
    Paul
    Knights of the Roundel #333
    Aug 2010
    North Ridgeville OH
    Maybe - but a more complicated explanation is needed. Does it always act like the side stand is down or up? Can you start the bike? If not, does the RID work? Can you put the side stand down with the bike running and not have it stall? Is this the same in gear and in neutral? Or in other words, how exactly is it not working?
    RK Ryder
    London, Ontario
    Quote Originally Posted by rxcrider View Post
    Up until a week ago, when ready to dismount the bike, with the bike in first gear, I'd lower the side stand and the engine would turn off. Now, with the side stand deployed, the engine continues to run. Starting the bike is not a problem, neither is turning it off by either the key or the kill switch. It was just more convenient turning the bike off with the side stand. What is RID?
    Paul
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Rider Information Display - the LCD display on the right side of the fairing, with the gas gauge & clock.
    Whether or not it works is a major clue in some troubleshooting cases; if it doesn't come on when the key is on, then an electrical fault is easier to pinpoint.
    In your case - not the issue. The sidestand switch is another nannycrat feature, to help prevent folks from riding off when the stand is still down (and we've ALL done it at some time...). The switch is subject to failure due to its exposure to the environment (rain, road debris, oil, exhaust heat); usually they fail "open" (no worky at all). Instead of buying a replacement, many people choose to just jumper across the wires, creating the condition you have now. If you want to R&R it, it's really pretty straight-forward, go for it.
    Aug 2010
    North Ridgeville OH
    Sounds like you probably have the rare switch that fails in a way that you can still ride the bike.
    At some point (and I don't know which year) a relay was added so you could have the engine running with the side stand down as long as you were in neutral. That creates one more question: Prior to the failure, could you have the engine running while you were in neutral, but not in gear or would the engine shut down regardless of the gear selection?
    Massachusetts
    Thanks in advance.
    The contacts on the sidestand switch, which passes the +12V from the kill switch to the starter switch, have fused themselves closed. Or the inside the switch actuator that opens the contacts has failed. I would be concerned I think that at some point they could open but then not close again. Hard to say. I'd be inclined to fix it.
    If the switch can be unplugged that would confirm it's the switch rather than the other possibility, which is that the two wires going to the switch are somehow shorted together.
    http://www.mac-pac.org/wp-content/up...Diagram-V2.pdf
    . AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    On the classic Oilheads (MA2.2) the sidestand and kill switches did the same thing; kill the engine and starter. There is an add-on relay harness to let you run the engine with the sidestand down.
    The MA2.4 bikes (1150-type) let you run with the stand down in neutral, but had that idiotic thing where the engine will still crank over.
    The MA2.2 with add-on harness and the Hexheads have 'normal' systems that work as one would expect.
    To the OP: sounds like you need to replace your sidestand switch.
    Anton Largiader 72724
    largiader.com bmwra.org
    Massachusetts
    This happens to me a lot when I'm running errands. It made me look hard at the schematic. If the output of the Motronic relay is connected to the input of the Start Button (after disconnecting its input from the Kill Switch) the starter won't turn over until the bike can actually start. It's only a one wire change.
    Jun 2012
    ...I was thinking about disabling that "feature" on mine...
    Bmuused 182242's Avatar
    Apr 2012
    Westchester, Illinois
    Lucky you. My old Suzuki had a side stand switch that would allow me to start the bike in neutral and only kill the engine when the bike was put into gear with the stand down. I have been toying with trying to do the same thing on my 1100rt, but it just isn't that high a priority.
    Good judgment comes from experience, but experience often comes from bad judgment.
    2UP RIDER snookers's Avatar
    Jul 2010
    Southwest of Beamsville
    Paul..... place the bike up on the centerstand and remove the sidestand from the bike. Then remove the sidestand switch and take it apart. You should be able to see if the switch is salvagable and clean and service it into working condition again. A great time to lube the sidestand bushing as well.
    2000 R1100RT
    Niagara BMW Riders #298
    BMWMCO #45
    Quote Originally Posted by 182242 View Post
    oddly enough, that is how my 2001 R1100S is designed to operate- sidestand down starts and runs fine, dies if you go into a numbered gear with s-stand still down.
    could not imagine a valid reason (other than to appease nanny lawyers) for having it operate otherwise.
    Victoria BC Canada
    I hate that darn switch. Just need to take the time to disable it.
