Results 1 to 4 of 4
Thread: 85 K100RS rear main seal seating.
    Nov 2005
    So despite wisdom to leave it alone, I went ahead and pulled the old one out. What happened next was:
    1. lots of oil started dripping out. Lesson learned, next time if I ever have to do this, do it before filling the engine with oil.
    2. the new seal is different from the old one. (see pic)
    3. It's almost impossible to drive the seal while having a panic attack as oil is dripping out. And using something trying to knock the edges in didn't work for me.
    4. Then I though since the clutch bell/housing/basket/whatever you call it sits right before (see image) the rear main seal
    I just placed the seal on the bell, inserted into the engine shaft and put the hex nut back and cranked to tighten. Now I have this:
    Chuck
    Current: 1985 K100RS
    Previous: 2002 R1150GS, 1990 Suzuki VX800, 1993 Honda CBR600F2, 1988 Honda CBRF, 1978 Honda Passport
    Nov 2005
    after:
    But it's difficult to see, the outer seal perimeter sits about 2 mm above the engine block opening. Don had mention it should be something like 0.5mm.
    I'm wondering, since the rear main seal sits next to the bell, and having it flush to the engine is bad, what would be the problem with having it sit high?
    ANyways, I also though I can place sticky tape on the engine opening for some spacer effect and use a wood block
    to drive the seal deeper if necessary.
    Feedbacks are greatly appreciated.
    Chuck
    Jun 2012
    Olympia, WA
    Quote Originally Posted by cy7878 View Post
    .... what would be the problem with having it sit high?
    The seal would get ripped to shreds by the clutch pack the first time you start the engine.
    Tim
    Olympia, WA
    1991 K75 - 121k Miles
    Nov 2005
    Thank you Tim. That's what I thought after sleeping on it.... I will try to pound the seal in a little more. The sticky tape I placed is 2 layers thick, which is too much. I will try with just 1 layer and repeat the pounding...
    Chuck
