Results 16 to 27 of 27
Thread: Newbie with a fuel leak
    Jul 2006
    Fairfax, VA
    Just reading your reply on the gas leak and the after market pre formed hoses for the innards you mentioned caught my eye. I cannot seem to source the short hose that does a 180 from the fuel filter. This is BMW part number 16 14 2 325 808 and it costs around $34. Seems only BMW makes this part. Tried purchasing a universal plastic replacement hose from Euro Motoelectrics sells but I realized it is going to be too long after it arrived.
    If you know where to find injection rated submersible hose with a 180 degree bend please let us know what and where to buy please.
    I also have, but not yet installed, the Euro Motoelectrics hose in place of the 180 degree OEM part. Could it be that it is intended to link the 2 nozzles after 540 degrees of rotation (180 + 360)?
    Jul 2006
    Fairfax, VA
    After looking at the hoses again, I see that they are not only too short to wrap 540 degrees, but come with instructions that describe the need to cut them to fit.
    Best regards,
    Mark
    Apr 2012
    Have you installed one? I ask because when I measured the original hose length vs the length of the bendable part of the nylon hose it seemed much too long. My concern is it would not fit back in the tank properly.
    I installed one about a year ago along with a new gas filter and hoses in a 2004 R1100S and it's working fine. I cut about an inch and a half on both sides of the straight tubing. You'll be using the straight portions of the hose for clamping.
    I replaced them because I read the older bikes were having problems with them. All the hoses I replaced were about 8 years old (original factory) - Their condition were like new, no sponginess what so ever.
    My concerns about the replacement nylon hose were:
    A. Corrugated portion might restrict flow - Hose is 5/16 inch diameter and I don't think our bikes drink that much fuel.
    B. It's Nylon - It has an A rating for gasoline and alcohol and heard cars use Nylon.
    C. Thickness of tubing - It's rated well over the 100 PSI ( it's 220 PSI rated) we need.
    D. Nylon tubing doesn't compress for clamping - I used Oeitiker clamps. Fuel hose clamps are supplied. Just be sure to pull enough of the straight tubing over the barb, and then clamp down after the barb.
    I don't think one should use an ordinary submersible hose for the bend because it's rather stiff.
    I would recommend a preformed hose from BMW or the Hose Kit from Euromotoelectric.
    Jan 2013
    Sulphur, LA
    You guys are diagnostic geniuses!! Pulled the side panel (after checking another old thread to find out how to "whack" the mirror off) and it's leaking at the disconnect. My question now before I spend the $75 on the all metal disconnect is....has anyone replaced the quick disconnects with some sort of straight piece of hose and fittings? Just wondering if you really need the quick disconnects or can you rig it direct and deal with the inconvenience of draining fuel on my next repair. If you did rig it, I'd love to know what you used. I was wondering if just putting in a small fuel filter between the two hoses would work???
    Thanks for all the help and suggestions guys....you were a life saver!
    cajun
    Massachusetts
    One thing you could do is buy some Viton O-Rings from Beemer Boneyard. Then see if your plastic QDs are sound, they may well be.
    Debbie's Servant Lee's Avatar
    SW Iowa
    Quote Originally Posted by cajunbeemer View Post
    The QDs are convenient, but are not required. You can go to about any parts store and get the correct size brass barb to connect two lines. Use a sleeve type clamp, not the cheap worm gear clamps.
    Lee 2011 K1300S
    MOA # 30878
    Vancouver, B.C. Canada
    There's not a lot of genius required to figuring out this problem. It's common and been written up here loads of times. As Roger04RT already stated you can first try replacing the viton o rings (simple easy fix) if the leak is from in between the two connectors and there are no breaks or cracks in them. If your current parts are OK and just need o rings this is the preferred fix.
    If you decide to go for the barb the size you need is 5/16".
    If you want to switch them out for a much cheaper alternative and plenty here would advise against it these do
    work:
    http://www.aerostich.com/gas-line-quick-disconnect.html
    $16 each won't break the bank.
    No matter what you do as Lee said use fuel injection hose clamps NOT the cheapo plumbing clamps. Like this one from O'Reilly auto parts. 52fseries.jpg
    Apr 2005
    Two quick thoughts. First, pretty much everyone agrees that thee QDs are worth the money. There are a bunch of maintenance tasks that require you to remove the tank. You'll be much happier if you have a high-quality set of QDs installed.
    Second, your current fuel lines are 11 years old. This is an ideal time to replace them. You will probably damage them getting the old QDs off anyway.
    So, buy a set of QDs and a few feet of 5/16" i.d. fuel injection-rated line. Rebuild the whole setup. Heck, as long as you're doing that, you might as well replace the fuel filter. Maybe pull it out of the tank and install it externally. Might as well bleed the brakes while you have the tank off also.
    Jan 2013
    Sulphur, LA
    On the road again! Thanks for all the tips. I ended up buying 4' of fuel injection fuel line and fuel injection hose clamps. I was able to carefully get the crimp-on clamps off without having to take the tank off and replaced the line from the tank down to the hard plastic lines. I know it will be little more inconvenient than having the quick disconnects but I like not having that potential leak spot hanging right over he heads.
    I'm ordering a repair manual but does anyone know where I can download or get an owners manual for an 1150RT? Dealer says they can't get the 1150 any longer.
    Thanks!
    cajun
    Massachusetts
    Here's an electrical link that has a good schematic: http://www.mac-pac.org/tech/electrical-diagrams/
    For manuals, as you probably know, Haynes or Clymers.
    If you PM me an email address I've got the document I believe you're looking for.
    RB
  11. #26
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    Last year I replaced the male end of the quick disconnects. I was told by Ted Porter at the Beemershop that the female ends arent a problem. All he sells are the metal male ends. I cant verify if this is true or not.
  12. #27
    Diamondhead, MS
    That would seem to make sense because the female end is supported by hose.
