Results 1 to 11 of 11
Thread: Q: Does Ilium sidestand foot loop snag...
    Ed Kilner #176066
    Mississauga, ON
    ...your pant leg?
    I do want to enlarge the sidestand foot on my R1200RT. The loop looks like it might help put it down securely. I do find this tricky sometimes. No tip over yet (that way!). However, a friend says it snags his pants on his V-Strom.
    So, RT guys - any user experience?
    Ed
    na1g
    May 2011
    I put the side-stand foot pad on my 2011 RT for two reasons: it enlarges the footprint to help keep the stand from sinking into soft pavement; and the loop makes it easier to find the side-stand with my boot to flip it down. Both those things are well done, but as you mentioned the loop can snag your pants. I haven't had a problem with falling over but have flipped the stand down unintentionally a couple of times, only when wearing my Draggin jeans which seem to have a wider leg than my Olympia overpants. This once led to an embarrassing situation right in front of the local moto hangout when I tried to start and ride the RT with the stand down. Twice. After I figured out the problem I modified (bent) the loop a little so it's not a problem.
    pete
    "Be yourself. Everyone else is already taken." -Oscar Wilde
    Apr 2010
    Western MA
    I cut down the loop a bit and re-welded it. I found that a 1/2" reduction did the trick for my legs/pants.
    Theo
    jdubeemer jdubick's Avatar
    Boaz Alabama
    I have had it on my 2010RT for two years with nary an issue no matter what I was wearing. It's one of the best farkles you can add.
    Jim Dubick
    Boaz, Alabama
    R1200RT,R100/7,KLX250
    BMW MOA, BMW MOAL, AMA, CMA
    Jan 2013
    I do not find that it snags.
    I do find that it's sometimes slightly harder to 'grab' the end of the stand, perversely enough; I almost think that the Wunderlich version would be better, because I had no real trouble deploying the stocker. But overall it works, and I appreciate the additional spread.
    Sheboygan, WI
    Smile
    Quote Originally Posted by jdubick View Post
    Same experience here - on the R1200RT for seven years - no issues.
    Excellent and practical addition!
    Kevin Greenwald - Touring Tips Editor
    MSF RiderCoach # 121656 (BRC,SBRC,IS,IME,SMARTrainer)
    Motorcycle/Driving Instructor - ROAD AMERICA Race Track
    Ed Kilner #176066
    Mississauga, ON
    Quote Originally Posted by holygoat View Post
    Searching the Wunderlich catalog for "foot" turned up lowering kits and the like but no foot extender. Touratech has some models though.
    Ed
    Geeser
    Nov 2006
    Annapolis MD
    I have it on my 2009 K1300GT with no problems over the last two years
    Marty
    K1600GTL
    F700GS
    IBA #42016
    Jack Herbst
    Jan 2008
    Oro Valley, AZ
    I will second that. Works great. No issues. Ridden with it for five years. When sitting your pant leg should rise up to the top of your foot or lower ankle if your pant is fitted correctly.
    Jack
    Dec 2009
    Hudson Valley, NY
    Mine never snags. It was the first (and probably one of the best) farkles I've added. I did end up stripping one of the screws though but I don't ever plan on taking it off so that hasn't been a problem.
    Craig
    2009 R1200RT
    MOA #146131 IBA #55715
    Jan 2013
    Quote Originally Posted by BMW Triumphant View Post
    http://www.wunderlichamerica.com/mot...T/8500046.html
