Results 16 to 30 of 36
Thread: brake fluid in clutch
    Urbana, IL
    Quote Originally Posted by Downs View Post
    Interesting. How many other manuf use Brake fluid in the brakes and hyd fluid in the clutch systems? I've never seen anyone else that does. Seems like for simplicity you'd use the same fluid the other hydraulic system (brakes) uses.
    BMW used Brake fluid in the clutch system until about 2005 or so. Depends a little on the model. A little later on the in line LT I think. Then they went to mineral oil.
    My other bike is a BMW.
    Nickname: Droid
    Jun 2005
    Green Bay, WI
    Because the R-bikes use a dry clutch it is unique compared to other bikes/brands with hydraulic operated clutches. A bike with a wet clutch, like 90% or more of the bikes on the market, is unaffected if the slave cylinder leaks oil. Won't harm the clutch but eventually the clutch won't work when there is no fluid in the system.
    BMW, Ducati, Moto-Guzzi are the only common cycle brands to use a dry clutch. The BMW is also unique because the clutch is inline to the driveline, not 90 degrees to the driveline like a Ducati. Moto-Guzzi, I think, only uses a cable operated clutch. So BMW is unique to use a dry clutch along with a hydraulic operated clutch.
    If other bike makers used dry clutch hydraulic systems its pretty likely they'd use non-brake fluid in the clutch system too.
    Urbana, IL
    The new R bikes will have wet clutches as the new GS for 2013 has. The rest will follow. The K bikes already have wet clutches and as well the G and F bikes.
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Quote Originally Posted by jbarneshb View Post
    Maybe they didn't need to use brake fluid in this application but in the interest of making things simpler and more idiot proof, I wish they would have. Is mineral oil any better than brake fluid in this application?
    Yes, mineral oil is better in this application. Brake fluid absorbs moisture and needs changing every so often. Mineral oil doesn't. My bike has this embossed on the clutch reservoir cap:
    WARNING
    CLEAN FILLER
    CAP BEFORE REMOVING
    USE ONLY MINERAL OIL
    SEE OWNER MANUAL
    jeepinbanditrider
    I understand how the driveline is setup I used to have an 1150R. I'd honestly rather see just a plain ol clutch cable setup instead of a hydraulic system of somesort. At least on these bikes it seems like it might actually be a step up in reliablity
    Ozzie Flyer
    Brisbane, Queensland, Australia
    Dont necessarily agree. If you use mineral oil I think the majority would find the hydraulic clutch actuation system is very reliable. More so than a cable. Also a lot easier to use. Clutch actuation issues on R's is pretty rare I believe.
    regards
    Paul
    regards
    Paul
    Ozzie Flyer
    BE KIND TO HUMANS... THEY BITE
    Maybe they didn't need to use brake fluid in this application but in the interest of making things simpler and more idiot proof, I wish they would have. Is mineral oil any better than brake fluid in this application? After I did this, I looked in my owners manual. It doesn't say anything about what fluid to use only to take it to a dealer if the fluid is low. On the cap it does say to only use mineral oil. It's my own fault for not making sure which fluid to use first.
    The problem with brake fluid is that if it leaks at the slave cylinder, when it migrates along the clutch rod it doesn't just contaminate the clutch. It damages both the transmission input shaft seal and the engine output main seal. Then they both need to be replaced. Mineral oil is compatible with those seals so won't damage them. It also won't attract moisture and there really isn't any required change interval as there is for DOT 4.
    All in all I consider it a big plus over the brake fluid.
    got, got, got no time... rguy's Avatar
    Aug 2003
    Rogersville, MO
    Correct. I asked my dealer if I could buy a pint of mineral oil to flush my clutch and they told me there was no regular recommendation to change it. They told me they could order me a quart if I really really really wanted. They did not keep any in stock except for what they kept for their shop.
    Neal - '09 R1200GS / '81 R65
    _______________________
    Be the person that your dog thinks you are.
    May 2011
    Mineral Oil (hydrualic) to operate the Hydraulic operated Clutch is fine with me.
    The benefit is its self adjusting and smoother.
    David
    Wilmington, NC
    +1 for what Paul said
    While I've got a bit of sympathy for someone who has made the mistake of using the wrong fluid just how much more do you think the manufacturer should do- the reservoir cap is clearly written with what is supposed to go in it!!! Maybe contrasting colors and flashing lights?
    READ THE LABEL - pretty simple...
    There might be some people who just don't know there is a difference between hydraulic fluid and DOT4 brake fluid. In such cases one has to wonder whether they are really competent to be messing with a $20K piece of machinery and ought to just take the thing to a competent mechanic- the good ones are always worth way more than you pay them. Even though I'm able to do my own work, I sometimes pay one of my competent friends in the business to do it- keeps my contact lines open, saves a little time, always gives me the chance to learn a few tricks from the good guys who turn wrenches every day - hey, I'm only a part timer at it and like anything else in life, there is always someone who knows something I don't.
  11. #26
    jdubeemer jdubick's Avatar
    Boaz Alabama
    I totally agree with you. I don't mind changing oil and simple tasks but these things are not like old airheads. I was at the National in MO last summer on my 2010 RT and a guy walked past me and pointed at my clutch reservoir with a disgusted look on his face and told me I needed to change the fluid before I ruined something. The bike only had about 5k miles on it at the time. When I got home and took it in to have the 6k service done I mentioned it to the expert mechanic who educated me.
    Jim Dubick
    Boaz, Alabama
    R1200RT,R100/7,KLX250
    BMW MOA, BMW MOALABAMA
  12. #27
    Dec 2009
    Huntington Beach CA
    Does anyone else want to rub salt in my wounds? I know it was my fault. After doing it I did see the warning on cap saying to use mineral oil. I had only owned one bike before with a hydraulic clutch and it used brake fluid. In hind sight it would have been cheaper to have a dealer do it. My only experience with the BMW dealer was after buying the bike a few months ago. It had been 1400 miles and 2 years since it's 6K service and service light was on. I paid $375 to change fluids and turn light off. that didn't include brake flush which they wanted another $110 for. I would gladly pay $80/hr for actual time spent working on bike but that's not how it works. I will continue to do routine maitenance but will be more careful in future. Even with a couple of mistakes, I still think I'll be ahead moneywise and learn a little in the process.
  13. #28
    Oct 2009
    Torrance CA
    Hey, it happens. I decided to start cycling out the power steering fluid in my Mazda. So sucked out about an ounce and poured in an ounce of PS fluid, with plans to do this 32 times. After I did this twice, I discovered it uses ATF not PS fluid. Who would have thought!
    Luckily, I only put in two ounces, and I continued my process with a quart of ATF. No problems with the car and only my own pride was damaged.
    1988 K75 Low Seat
    2009 R1200R Roadster
  14. #29
    Does anyone else want to rub salt in my wounds? ...........
    Live and learn, we all have done things like this.
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
  15. #30
    May 2007
    Raleigh, NC
    I fix most anything myself. I'm WAY ahead on the money, and there's knowledge, independence, and satisfaction that goes with it. If I beat myself up over a little mistake once in a while I'd be quite unhappy. Write it off, move on, and be happy with the money you save in the longer term.
    Rob C. , Raleigh, NC
    '10 R12RT, R90/6
    2007 CBR600RR & 09 V-Star
    Suzuki DR 350
