Results 1 to 2 of 2
Thread: Bleeding rear brake
    Aug 2004
    New Braunfels,Texas
    Bleeding rear brake
    Today I decided to bleed the rear brake on fairly new to me 82 R100rs. It's always been a little mushy with too much pedal travel compared to my other airhead with the same Brembo disk. I pulled the caliper away from the disk so that I could rotate the nipple up to make it easier to get any air out of the system. Applied pressure to brake pedal and opened the bleeder and got some air bubbles and fluid out and then closed and repeated. Never did get the brake pedal to "pump up" after many repetitions.Anyone out there able to give me a suggestion on what I should try or what I might be doing wrong? Only thing I can think of is I might be getting air into the system between the bleeder and the caliper body.
    Registered User wvpc's Avatar
    Dec 2009
    Ypsilanti, Michigan
    Search is your friend
    Lots of threads on this if you do a search. Lots of different methods. I bought a reverse bleed kit off Amazon. Good luck.
    http://www.bmwmoa.org/forum/showthre...ear+disc+brake
    http://www.bmwmoa.org/forum/showthre...c+brake&page=2
    12 R1200 RT
    83 R100 RT
