Results 1 to 6 of 6
Thread: r80 sidecar project
    Jun 2006
    r80 sidecar project
    I am planning on building a sidecar rig with a 1979 r80/7. Will an earls fork assembly from a/2 bolt up to my /7 steering head?
    Pismo Beach, CA
    Welcome abroad smitty.
    This sounds like a question well suited for the boffins over at the Sidecars & Trikes forum.
    Lew Morris
    1973 R75/5 - original owner
    Lew -
    I thought the same thing too, but he has specific questions associated with the Airhead.
    No longer a member here
    I don't think the Earle's /2 unit would be a good choice for a /7 sidecar conversion.
    Don't even know if it is possible to fit a disc brake into that fork.
    I would look for a leading link front end for a more modern unit.
    Maybe Hannigan can set you up with soemthing
    Astatula, FL
    I would get on ADVRider and ask at the Hacks Forum.
    I would also contact Chris at http://boxermetal.com/
    He can answer any question regarding fitting the Earles fork, and how to upgrade the braking.
    Good luck with your project.
    Bob Weis
    '04 K12RS - Hannigan Hack
    www.earplugco.com
    May 2008
    B.P., MN
    As to the /2 front end fitting a later frame, I'm looking at BMW Motorcycle mag, issue summer, 2012, page 54, and a stunning performance hack with an R90S motor in a /5 frame with an R69S earls front end. Don't know how it works, except it looks like it goes and handles. IMO
