Page 1 of 4 123 ... LastLast
Results 1 to 15 of 53
Thread: 1973 R75/5 Rebuild Project Journal
    B Reams brook.reams's Avatar
    Arvada, Colorado
    Post 1973 R75/5 Rebuild Project Journal
    I'm rebuilding my wife's 1973 BWM R75/5 with 97,500 miles. I documented how I restored the Bing carburetors with photos and procedures plus a Bing exploded view of the carbs as a guide. Enjoy.
    http://brook.reams.me/2013/01/04/197...r-restoration/
    I'll be posting more material as the project progresses.
    Brook Reams - Arvada, CO
    Various Two-wheeled Vices, All BMW
    2004 R1150-RS || 2002 F650-GS || 1975 R75/6 || 1973 R75/5
    Sheep Dog
    Apr 2007
    South Central Indiana
    Bing carb rebuild
    Fantastic rebuild documentation. Thank you so much. I'm in the process of restoring a 1974 R90/6 with a Velorex 562 sidecar. Your post comes along at just the right time.
    Beemerphan Radar41's Avatar
    Longmont, CO
    Smile Bing Rebuild
    Quote Originally Posted by brook.reams View Post
    VERY NICE photo's! R75's are awesome .
    Don "Radar" Wreyford
    00 K1200LT, 98 R1100GS AE, 84 R100RS, 76 R75/6 (rebuild complete)
    MOA # 91738, RA #27032 , ABC #7915 - "Insanity is doing the same thing over and over again, but expecting different results" - Albert Einstein
    Aug 2004
    Walnut Creek, CA
    Great documentation on the rebuild. I have only one comments. The screws are peened on the butterfly to prevent them from accidentally backing out and getting sucked into the engine. As such, the backs of the screws need to be filed down to prevent stripping the threads on the throttle shaft. DAMHIK The shafts themselves are not very expensive ($10-15ea), so it's not the end of the world if you do strip them.
    When installing the new screws, they should be peened or others (including myself and the OP) have used loctite. According to the experienced people/guru's I've talked to blue loctite is more than adequate for this application. Red loctite, I've been told, is overkill in this situation. Some people do not recommend using loctite, and peen their screws.
    Anyway, great write up and keep up the rubber side down.
    Jeff in W.C.
    Arvada, Colorado
    Jeff,
    You are absolutely correct on the peening of the screw. Preventing them from mangling the threads in the throttle shaft makes perfect sense.
    Red loctite is "permanent" locktite IMHO :-)
    You are correct about the shaft (13 11 1 336 585) being pretty inexpensive.
    Thanks for reading this over and providing your input.
    Best.
    Brook.
    Quote Originally Posted by 88bmwJeff View Post
    Arvada, Colorado
    Cool beans. Glad this was timely. Check out the the other post I added today with the documentation for the rebuild of a 1975 R75/6. Could be some things their that are useful.
    Best.
    Brook.
    Quote Originally Posted by rcockrum View Post
    Arvada, Colorado
    1973 R75/5 Fork Rebuild Post
    Folks,
    I just posted material from my experience rebuilding and refinishing the forks on ny wife's 1973 R75/5.
    http://brook.reams.me/category/mc-rebuilds/
    Here's a look at before, and after.
    Faring & fender off
    Getting Started
    Fork slider details
    Sliders Disassembled
    After Rebuild & Polishing
    Rebuilt and Refinished
    Enjoy. Feel free to add any comments and tips to the my project web page if you wish.
    God? What god? RoboRider's Avatar
    May 2007
    Raleigh, NC
    Nice. I have some /6 forks to do and I will read your thread.
    Rob C. , Raleigh, NC
    '05 R12RT, R90/6
    2007 CBR600RR & 09 V-Star
    Suzuki DR 350
    May 2008
    B.P., MN
    Plus on your work, the clean work space and the great web page.
    Arvada, Colorado
    Quote Originally Posted by 8ninety8 View Post
    Thanks for the kind words. It takes me 1/2 as long to work on a project if I don't have to keep looking around for what I need. And as I get older, I have to look around much longer to find stuff I just had in my hand ..
    May 2007
    Raleigh, NC
    What's on your floor? Is that rubber mat? Expensive?
    '05 R12RT, R90/6
    Suzuki DR 350
    Arvada, Colorado
    Hi Rob,
    I got this from these folks in Grand Junction, CO., Garage Flooring, LLC.
    http://www.garageflooringllc.com/blt-garage-floor-mat/
    The BLT product is available from a number of distributors. I bought a 9' x 20' roll @ $425 plus $21 shipping.
    It makes the shop quieter, it keeps parts from bouncing as much so they don't richochette into some dark corner, and it makes it very easy to clean up oil and grease. A drawback is when you put a bike on the center stand for awhile, it makes a dent in the mat. I had some spare scraps and used a small piece under the center stand at first, but then I found aluminum diamond tread at a local outlet and picked up a couple 0.125" by 1' x 2' sheets that I use under my bike's center stands and a 2' x 2' sheet I use near my work bench. I picked it up from these folks who are in Denver, CO. I suspect you can find a local supplier near you.
    http://www.cutsmetal.net/
    The mat and aluminum diamond tread works great. As you can see, I have my R1150-RS apart right now getting the Ohlin's shocks rebuilt.
    Arvada, Colorado
    1973 R75/5 Wiring Harness & Electrics Disassembly Post
    Folks,
    I just published a new web page for the project on this topic. Here's the blog post with link to the web page showing detailed pictures
    http://brook.reams.me/2013/02/17/197...and-electrics/
    Here are a couple pictures.
    Starter Relay, Front Side Wiring Detail
    Starter Relay Wiring
    Tail Light Wiring Diagram
    Taillight Shell Wiring Detail
    Wire Loom Detail - Rotting Rubber
    Rotting Wire Loom Routing Detail
    All the web pages for this project are listed on the right side of my site with short summaries in the MC Build Projects category page.
    As always, comments, tips, tricks and "did you know you could have ..." comments are welcome. Feel free to post them on the web page.
    I hope you find this information helpful.
    Best.
    Brook Reams
    Jun 2007
    Minneapolis, MN
    Thanks Brook - freshening up a '73 R60/5 & taillight frame needs repainting - was a little alarmed when I sar all rose wires crammed in the receptacle!
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    Arvada, Colorado
    Quote Originally Posted by kentuvman View Post
    Hi Ken,
    Indeed, but wait until you look inside that headlight shell. I'm going to leave well enough alone and stay out of that rats nest as best I can. :-)
    Best.
    Brook.
