Results 1 to 4 of 4
Thread: Just Finished Brake Fluid Service On My 08 RT Via Mr. Semper-Fi, Observation
    Jeff cookie's Avatar
    Jun 2008
    Paradise, CA
    First, thank you Don! I just completed the task with the help of MOA's Technical Center.
    This step by step approach really helps make it simple.
    I did notice the Mighty Vac tubing does not fit quite right and tends to suck air.
    I think next time I will get some flexible quality clear tubing in sizes to fit the bleeders.
    The Mighty vac helps but the manual method is easy also.
    If you have the tools and basic mechanical sense go for it!
    Jeff Anderson
    I ride a 2008 R1200RT
    Dec 2009
    Huntington Beach CA
    The dealer I go to wanted $110 for this service which made it worth my time to do it myself. Most of the regular maintenance is pretty straight forward. Just can't reset that service reminder without buying that $350 GS-911 coder reader as far as I know.
    jeepinbanditrider
    The boxers are about the easiest bikes out there to work on too. Valve adjustments take 15 minutes, plugs even less time. Throttle body sync is easy and doesn't take much time either. You can save yourself a boatload of money doing even the basic maint.stuff yourself as opposed to paying BMW shop prices.
    May 2011
    Quote Originally Posted by Downs View Post
    I know I save money. I also know I get a better job.
    David
