Results 1 to 7 of 7
Thread: Can you help identify this R1200RT part?
    May 2011
    Can you help identify this '07 R1200RT part?
    While removing the front headlight nacelle on my '07 R1200RT, I found a part on the garage floor and have no clue as to where it goes! It appears to be a vent tube, for lack of a better description. There are two, identical to this third one that I found, on the rear of the headlight assembly (forgot to take a picture before reassembling), about 1/4" from the side parking light bulbs, one on each side. I suspect they are "breather hole covers" to help prevent condensation inside the clear housing for the 5 lights: 2 parking, 2 headlights, 1 high-beam. It's made of soft rubber, is hollow.
    But where does this third one belong?!
    Steve Cottrell
    '69 R75/5 (why did I ever sell it?)
    '07 R1200RT
    AZ
    That is a vent tube. I believe it lets condensation out of the headlight assembly (as you said). You should put it back on if you ever ride in the rain!
    I am looking at my RepROM now to see if I can find all 3 of them...
    MOA #107139
    RA #28511
    YB #2005
    Camas Valley Oregon
    One each on low beams and one on high beam. 2 + 1 = 3
    Quote Originally Posted by AZgman View Post
    The only spare parts available for headlights are bulbs.
    na1g
    May 2011
    Cars use similar vents so maybe you can find one that fits. Also check m-c and auto boneyards.
    pete
    rabid reader dbrick's Avatar
    Santa Cruz CA
    It's very similar to the vent tubes mounted on the headlights of my 2001 VW Passat.
    David Brick
    Santa Cruz CA
    2007 R1200R
    May 2011
    Thanks, everyone! It sure makes sense to me, that it's a vent, since I see 2 more on the low beams. However, I see NO fitting to accept this third vent tube, even on the high beam section of the assembly. I hesitate to take it apart again until I know exactly where it goes. I don't know what a RepROM is, but if it shows a diagram of the location of this 3rd vent, then I'm VERY interested! I'm assuming that I'm looking for a vent hole, molded into the headlight assembly, that is the same diameter as the rubber vent tube. (It's not a pinhole, is it?) With the assembly on my workbench, under bright shop lights, my glasses on, I was unable to determine the location.
    A picture or diagram would sure be nice!
    steve
    Steve Cottrell
    '07 R1200RT
