Results 1 to 12 of 12
Thread: Locate Old Post - Brown Sidestand Install (Improved)
    Monza Blue 1974 R90/6
    Delaware
    In the last year or so, there was a reply to a post showing in improved method of installing a Brown side stand.
    The reply included at least one picture and I think the featured bike was an R100RS.
    The improvement was to add a piece of flat bar stock to that the Brown side stand did not use the exhaust clamp as an attachment point.
    I've been through the search feature on three different occasions over the last few days and cannot find this post.
    Does anyone else happen to better at finding stuff; or, could the smart fellow who came up with the improved install re post the pictures?
    Cheers, Barron
    sMiling Voni's Avatar
    Delaware
    Nope! (But thanks for looking.)
    That post shows the stock install which uses the exhaust clamp as a primary mount point. The reply I am thinking about had (as best as I can remember) a really elegant solution that extended the mounting plate, using a flat bar, up to the front motor mount, to keep pressure off the exhaust clamp.
    I think they bike was an RS because I seem to remember fairing lowers in the picture.
    Searches I tried were "Brown" (seemed logical) and "exhaust clamp". No luck.
    Barron
    May 2012
    VA
    Not in any way an old post on BMW MOA, but here is info from Snowbum's site: http://bmwmotorcycletech.info/FarleyBrownSurefoot.htm
    Stan
    AH# 13238
    Fenwick, Ontario Canada
    Brown Sidestand Improvement
    I know the thread you are looking for because I copied it.
    Mine improvement is not as nice as the origional but it works.
    Hope the picture show up!
    Knights of the Roundel #333
    1977 R100RS with 516,000 miles
    Lake Saint Louis, MO
    This is the way I modified mine.
    And the front mount. Takes the stress off the clamp around the exhaust pipe and puts it on the front engine mount bolt.
    Delaware
    That's it! Thanks a mil$, fellows.
    Barron
    Wisconsin and Florida
    "Takes the stress off the clamp around the exhaust pipe and puts it on the front engine mount bolt."
    These modifications are unnecessary and a waste of time to create more complexity where the original design is simple and sufficient.
    So long as the motormount bolt is tight there is no "stress" on the exhaust pipe whatsoever
    The forward projection of the original design to the exhaust pipe clamp only acts like a lock washer on steroids for the motor mount bolt attachment
    All significant "stress" of leaning onto the stand is taken by the motormount bolt and the exhaust clamp only prevents the fixture from rotating
    on the motormount bolt - very little "stress"
    The only rational reason to do something like this modification is where there is a non-standard exhaust on the bike and the pipe is not there to clamp to
    Much better modification if you think you need it is to use a better grade of motormount bolt - I have seen several Brown type stands snap off the
    motormount bolt
    I disagree! after breaking the left exhaust clamp twice.
    I put the bracket assembly on the modified Brown Side Stand and it no longer stresses the hanger bracket.
    I also disagree with the fact that the motor mount can be tightened enough to prevent rotating. I have made this modification on 3 bikes. On the first two (both moto-shock) bikes I did not even use the exhaust clamp, just let the extension take care of the stand. On the last modification (my Motorsport) I put the exhaust clamp back on, not to support the stand, but to support the exhaust system. I too have seen these clamps break because of the leverage of the stand putting stress on the clamp. After all, it is a lever about 14 inches long to the fulcrum (engine bolt), then about 2 to 3 inches to the other end of the lever. This would multiply the stress a lot even if the engine mount bolt is tight.
    Wayne
    Registered User kwb210's Avatar
    Jul 2009
    Washington, the state
    I have broken the left side exhaust clamp once
    Quote Originally Posted by DARRYL CAINEY View Post
    I agree that there must be some additional pressure on the clamp due to the stand. I don't have 500,000 plus miles on my 1977, holy cow, just a bit over 100,000. I am VERY careful when I use the brown stand. I always look to see that that the stand is levered forward, then I watch it make contact with the ground as I begin to dis-mount the bike. My point is I don't just "drop" the weight of the bike onto the stand thus making more stress than needed. The other reason I do that "process" of carefully making sure the stand is down by looking at it is when I am tired at the end of a day of riding I do not want to make the mistake of leaning the bike over only to realize I have forgotten to put down the stand!
    Regards,
    Kurt
    1977 R100/7 1972 R75/5
    1974 R90/6
    1975 Norton Commando (I'm not different...I'm a Norton)
    "Objects in the mirror appear to be losing" unk
