Results 1 to 9 of 9
Thread: fuel pressure regulator relocation
    slowrider
    Just wondering if anyone has relocated their fuel pressure regulator from under the airbox? I have a 2004 1150 GS w/85000 miles and last winter I did quite a bit of riding and it seemed like everytime the bike was started from cold it developed a gas leak from the regulator area. If I shut off the bike, waited a few minutes and started it again it would not leak ( never leaks in warm weather ). I'm suspecting the regulator or the plastic lines are the problem. Just put the bike on the lift table to raise the subframe, remove the airbox and replace the plastic lines with FI hose. Thought it might be a good idea to get the regulator out where you can see it. Any thoughts ?
    Nickname: Droid
    Jun 2005
    Green Bay, WI
    Guess I don't agree as I have a lot of miles on my 94 RS and its still on the original fuel regulator. No leaks. Being in Wisconsin I have frequently started the bike in sub 30 degree temps with no issues. The regulator and fuel lines from it are all original. Before attempting to relocate it I would inverstigate the leak issue a lot more, find the real cause/source.
    +1 on Andy. 95K, never a fuel related/regulator issue here either. have not heard of that as a common failure item either- fix the leak, and close it back up.
    slowrider
    I agree about fixing the leak, but you can't see the regulator where it's located and once you expose it ( subframe raised, airbox and throttle bodies removed ) the engine can't be run to test it.
    May 2011
    new regulator, new lines.
    Finito!
    Massachusetts
    Quote Originally Posted by tomtietjen View Post
    If you search on the advrider Oilhead forum you will find someone who has done just that.
    The pressure in the fuel lines is high enough that it's hard to understand how it leaks sometimes and not others. Your leak may not be the regulator. How do you see in there?
    slowrider
    Thats the poblem, I can't see in there. If the bike is on the center stand the gas runs down the trans and drips off the swingarm, if on the side stand it runs along the plastic fuel lines. I'll ck out the ADV site for info.
    weryoung
    Fuel Hose Failure?
    Those are the same symptoms I had when my rubber hose fuel lines that connect the plastic lines to the Quick Disconnects delaminated internally, and then the Oetiker clamps got loose...leak when cold, stop after warming.
    There was a recall on those rubber fuel hoses for my 2002 R1150R, but I had replaced them before it went in to effect. Be sure to use only fuel-injected rated hose (type SAE J36R9).
    Apr 2005
    I've had a similar problem before. The leak was at the connections between the hard plastic lines and the rubber lines. They would leak when it was cold. Maybe the fuel lines shrink when the temeprature drops. The fix was to replace the clamps and tighten them ... uhhh ... significantly.
