Results 1 to 3 of 3
Thread: final drive oil change video
    mattituck new york
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    Newer 1200's have the drain at 6 o'clock and separate fill plug, so the ABS sensor doesn't have to be removed if just changing the FD fluid.
    My Motorrad
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
    BMW says replace, not reuse, the big nut on the bolt connecting the link to the final drive.
    New specified quantity is 180 cc, down from previous 200cc.
    The mystery screws he works with from the inside secure the brake line plastic cover to the swingarm.
