Results 1 to 14 of 14
Thread: '04 R1150RT - Speedo
    Aug 2005
    Somers, NY
    not working!
    And yes, i have replaced the cable. Anyone else ever had this issue? Is it something that can be repaired by one of the esteemed vendors? The last thing that i want to do is to have to buy a new one.
    Thank you,
    sdc
    Somers, NY
    Just enjoying the ride.......
    Registered User pettynerd's Avatar
    Oct 2008
    Menomonie, WI
    I had the same thing on my 04 RT, turned out to be the little plastic ring inside the speedo hub, my receipt says it was the Drive Ring. I do have an extra speedo for cheap if it's needed.
    Aug 2005
    Somers, NY
    Hey Petty
    were you able to get yours repaired? or did you have to replace with a new/used one?
    TIA
    Somers, NY
    Oct 2008
    Menomonie, WI
    They (MAX NH) were able to reajust the existing one, cost like $25
    Mar 2006
    Speedo
    Have you changed the tire?
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Check out the speedo drive and the drive washer item #7. Typically that is where the problem usually is. The tabs get bent back if the wheel hub is not positioned correctly upon replacement of the front wheel. Fixed a few now.
    http://www.maxbmwmotorcycles.com/fic...png?v=08102012
    Ufda happens..........
    It's all about the details.
    As mentioned, probably the wheel does not engage the drive. There is a metal ring with two tabs in the hub of the wheel that needs to engage the tabs on the speedo drive gear. If not aligned so the wheel tabs are between the drive tabs they bend, and after a while friction won't keep them connected any more.
    I would remove the wheel and check that ring and its tabs. I'd also check the gear teeth in the drive itself.
    But before you do this, just disconnect the bottom end of the cable and spin the front tire. Observe to see if the metal tang that drives the cable turns when you spin the wheel. Then put your finger on that tang to create a little drag and see if it still turns when you spin the wheel.
    Aug 2005
    Somers, NY
    Interesting....
    yes i had changed the tire before it started happening. But the speedo worked for the first few hundred miles and then quit. Does that sound like it might be the part in the wheel that may be the problem?
    Or the speedo itself?
    TIA
    Somers, NY
    Quote Originally Posted by sdpc2 View Post
    TIA
    What? you want to spend money?? Check the part to see if its bent and that it is engaging properly before doing anything else!
    Geez.
    Left Coast Rider
    Vancouver Canada
    TIA
    "If not aligned so the wheel tabs are between the drive tabs they bend, and after a while friction won't keep them connected any more."
    TIA
    Yes - if the tangs are pressing on the tabs on the drive friction will hold them for a while. Then they will slip. They may grab and slip a few times but then they just slip. Voni's RS started to slip completely about 4,000 miles after I kludged the wheel install. I also fixed a case where a dealer replaced the drive (erroneously) but didn't straighten the bent wheel ring and it worked for 250 miles because everything was meeting tip to tip. This was at the start of an LD rally. I pulled the wheel, re-bent the ring tabs straight and put it back together and it worked fine.
    You need to just pull the axle, roll the wheel forward about two inches, and then bend the tabs back out so they are parallel with the axle and carefully put it back together so the wheel tabs are between and not lined up with the drive tabs.
    Sep 2011
    R1150RT Speedo
    Thank Heaven for PGlaves!
    Mar 2006
    Quote Originally Posted by 94aero View Post
    Oh, my...... I'm so happy we came to the same conclusion!
    Left Coast Rider
    Vancouver Canada
    ...after I kludged the wheel install.
    Hang on just one second...I feel a disturbance in the force.
