Results 1 to 15 of 27
Thread: Impact wrench or Breaker bar
    Merlin III
    I am attempting to remove the top nuts on the forks of my 1150GS so that I can drop the forks and re-route the brake line and cables for a ROX riser installation. I can't break the nuts with my 6 inch ratchet so I either have to get a breaker bar or an impact wrench. Are there any recommendations here? The torque value for the nuts is 40lbs. They may be over tightened or be some degree of seized up.
    I went to Sears today and all they seemed to have were impact wrenches. What would be best, a 2 ft breaker bar or a plug in electric impact wrench? Any brand recommendations?
    Braintree, MA
    I keep a 12 inch breaker bar in my toolkit on the bike. You very seldom need more than that. What kind of bolts are they? If hex head, use a 6 point rather than 12 point socket.
    -Tom (KA1TOX)
    Outlander Omega Man's Avatar
    Mansfield,MA
    What size is the nut- 10 or 12 mm? I'd soak it with any of the brand name penetrating oils and use a standard size 3/8 breaker bar. I'd try to tighten a smidge then loosen a smidge and work it loose. If that doesn't work, I'd move to a hand impact (hit with a hammer) driver to kinda shock it loose. A quick spin with say a half inch air impact will probably snap the bolt. Good luck. OM
    2009 F800GS 1994 TW200
    Part of the Forum Threadside Assistance Program
    Merlin III
    The nuts are 14Mn hex.
    Mansfield,MA
    Quote Originally Posted by Merlin III View Post
    Same deal. The inherently shorter length of the 3/8 breaker bar helps from applying too much force. Go easy, as no doubt from age and salt exposure, there is some corrosion. OM
    Braintree, MA
    I once bought an 18 inch breaker bar, but only ever needed it once on a counter sprocket nut. Big bar, 1/2 inch drive (but still cheaper than bringing the bike to a shop).
    The 10" or 12" 3/8 drive breaker bar is the one that gets a workout when I do bike maint. If you need more oomph, put a short pipe over it or whack it with a hammer. That's why I like 6 point sockets. They won't slip like 12 point ones sometimes do.
    -Tom (KA1TOX)
    Rpbump USN RET CPO Rpbump's Avatar
    Jan 2008
    Jacksonville, FL
    Thumbs up
    Use some KROIL (the oil that creeps) and alternately use a breaker bar to tighten/loosen the nut. If the nut was fastened with thread lock use your wifes hair drier on the nut the use a suitable wrench or breaker bar. Patience can avoid many problems as brute force many times leads to costly & time consuming repairs.
    RIDE SAFE
    Cave Contents: 1980 R100RT/Ural Sidecar, 2004 R1200CLC, 2006 HD FSXTI
    Ride Safe
    Merlin III
    Quote Originally Posted by Rpbump View Post
    RIDE SAFE
    Well I tried Kroil and a breaker bar to no avail. Is it standard procedure for BMW shops to use thread lock on the top fork stud-nut? Is a standard hair dryer enough or do I need something something a little stronger? I am not exactly sure what that something would be. I would be a little nervous trying to heat up the nut-stud with a propane torch?
    Eastern KY
    NO! on the impact! Better to try the breaker with a 6 pt as stated and to tap the bar end with a soft blow hammer while also using the Kroil or similar. May also help to just go ahead and beat on the breaker bar with a ball peen hammer to give an extra "shock" to the part. The use of an impact there will cause something to give & you may not like the result.
    It is not clear to me which fasteners we are talking about. My assumption was it was the fasteners that hold the top of the forks to what might be called the triple tree at the top. If so, I strongly suspect they have been treated with a high strength thread locker. Not sure, but that is my hunch.
    That is precisely what BMW usually does with what they believe are critical suspension system fasteners. Given the size of the stud, excess force could easily shear it before the thread locker would release. That will be expensive.
    Usually the pinpoint application of heat to the fastener is required if they used high strength thread locker. I wouldn't go any further without consulting a factory repair manual.
    Mar 2006
    Nuts
    Paul is right, they do have blue thread lock on them. Use a heat gun till they are about 150 deg. They will still be tight but mushy. You will have to hold the tube with your hand.
    Vancouver, B.C. Canada
    +1 on what Paul said. I just did my seals recently and those nuts are threadlocked for sure. Looking in the factory manual it says they used Loctite 2701. Fork diagram assembly shows the heat gun at 120C.
    I found heating the nut with a pinpoint flame worked pretty well in this location.
    Merlin III
    Yes, that nut is on top of the triple tree. Thanks for all the great help. Now for an education on heat guns or pinpoint flame devices. Would something like a soldering iron placed judiciously on the nut do the job or is there a specific device called a "heat gun" that I should purchase? If anyone has brand names or devices it would be very helpful. Thanks again.
    (Edit, after researching Loctite) I would have to guess that someone used red Loctite on these nuts. After reading articles on the subject, a lot of people say that you can break Blue Loctite with a breaker bar. The subject bond seems nearer to a weld to me, but then again my experience level is low.
    Jul 2010
    Tularosa, NM
    Heat Gun
    Harbor Freight has heat guns on the cheap, and the quality is OK for items that are basically a little fan and a heating element. These guns may look like a hair dryer, but they operate at much higher temperatures. Don't dry your hair with one of these!
    These are usually safer to use than an open flame for many applications, and the "brute force" alternative is a bad choice when talking about a fastener that has been threadlocked with something requiring high-temperature release.
    Good comment on tapping a breaker-bar with a METAL ball-peen if a dead-blow hammer fails. Vibration can "crack" the corrosion and loosen the fitting, and if you have access to the fitting itself, tap directly or with a drift before applying pressure or heat and see if it releases.
    Depending on what kind of "life" an older bike has had, ("You don't know where that's been!") fasteneners can look OK on the outside, but will have lots of corrosion on the threads when removed.
    Patience, and the application of reasonable force + penetrating oil works wonders. Sometimes TWO DAYS worth of Liquid Wrench, Kroil, PB Blaster, etc. is called-for. Waiting is better than expensive repairs to critical threads. . . and it's WAY better than the feeling of that bolt twisting off. . .DAMHIK
    Walking Eagle
    Wilmington, NC
    A shop heat gun is $10 at Harbor Freight. Mini torch flames work if used carefully. Unlkely a soldering iron will do it well unless you've got one of the old 250W or more ones.
    Due to shrining electronics, most of todays irons are wimpy and for tiny stuff. A soldeing iron is slow and will tend to heat the whole part before it gets anything hot enough to break a threadlocker on bigger stuff. (I get a lot of use out of my almost 50 year old Weller that can do 325 W)
