Results 1 to 14 of 14
Thread: What to do with PIAA's
    Aug 2011
    I just got a set of PIAA 1100x driving lights for my 2007 1200rt. My question is - How are you guys mounting these up? What are you using for brackets? Where are you putting them - fork legs or under the radiator, etc? What are you doing with the switch? Any help would be appreciated..
    One big Oaff brewmeister's Avatar
    May 2009
    central wisconsin along the wisconsin river
    You want to creat a triangle with the headlight being the top of the piramid then your piaa's the bottom two corners of the triangle.Try and make them as far apart as you can.The brackets are another thing.
    81 R100RT
    Aug 2005
    Somers, NY
    I agree with what brewmaster said
    but under the category of do as i say, and not as i do....
    Mine are under the chin on my R1150RT as i didn't want to be paying for more than one set.
    Somers, NY
    Just enjoying the ride.......
    Diamondhead, MS
    Quote Originally Posted by brewmeister View Post
    Brewmeister is absolutely right. The other advantage of doing this is it reduces the amount of "back scatter" that your eyes have to deal with.
    Can you mount them on the fork legs? That will give you a good triangle of light with quite a bit of distance between the headlight and the DLs, as well as allowing directional aiming of the lights when turning, walking, etc.
    fwiw- in 10 years of using my PIAA 1100Xs mounted like this, i have yet to have a car pull out in front of me.
    Diamondhead, MS
    I have a set of Hellas mounted like Bikerfish on my R1150R with yellow bulbs. When those things are on, EVERYBODY sees me coming. I usually us them in fog, rain, and congested areas. If I am following someone I usually turn them off. No one has ever pulled in front of me when they are on.
    I put them on the bike just to make me more obvious to traffic.
    Aug 2011
    so what did you use for mounts on the fork legs? Any close up pictures? Clever ideas for switch mounting?
    RK Ryder
    London, Ontario
    Mine used to be mounted under the front grill but not a lot of separation and they occasionally hit the fender. Removed the roundels at the side and the PIAAs fit there quite nicely, as well as creating a larger triangle.
    Paul
    Aug 2011
    The rondels on the side fairing? I want to make sure I know what you are talkingabout..
    RK Ryder
    London, Ontario
    Quote Originally Posted by stokesrl View Post
    The lights easily unplug before removing the faring for servicing. The light triangle is very large.
    Since last year, I have added a smaller roundel above the 1100.
    Hope this image helps.
    Paul
    Proud Veteran SteveAikens's Avatar
    Clovis, NM
    Under the mirrors. The higher you install the lights, the more illunination you get from them. The mounting brackets are from BMR.
    I have a couple GPSs on a BMR Shelf. I mounted the switch where it's out of my line of sight but easy to reach behind one of the GPSs.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
    Aug 2011
    Thanks Steve.. Look like you have a small triangle :-)
    May 2009
    My piaa's where mounted at the point of where the BMW rondels were located when I first bought my r1100rt .Later I mounted them on talon brackets on the valve covers.I don't want to get into the pros and cons of these brackets cause they work for me and I'm happy with them.
    81 R100RT
    May 2009
    Here is the piaa's mounted on the talon brackets. They are nice and wide apart and work well in this position.I wired them so they don't have to be removed when I have to remove the plastic to do tune up /service under the plastic
    81 R100RT
