Results 1 to 9 of 9
Thread: Oil Filler Cap Problem
    143439 bobr9's Avatar
    Jun 2012
    Clarkesville, GA
    I have a 99 R1100RT with an aftermarket oil filer cap installed by PO. The cap is the metal type requiring an allen wrench for installation/removal. My problem is that when I put it back on the other day after topping off the oil, I tightened it to the point where the whole assembly now just turns (by whole assembly I mean both the cap and the insert liner that it screws into).
    So I am looking for suggestions on how best to get it out. I am thinking it may be best to just pry it up with a screwdriver, but wanted to see if there was a better or less destructive approach. Thanks..
    Quote Originally Posted by bobr9 View Post
    I think there is a better way. What has happened is that the little set screw(s) that hold the outer part are now slipping. On most designs the outer part is hard to see, let alone hold from the outside.
    I think you will have better luck from the inside. Take the valve cover off and see if a screwdriver tip can't jam a bit and hold the ring while you remove the cap.
    the set screw on that filler housing is accessed from the inside of the valve cover. doubt you'll need anything more special than the corect size allen key. it is smalll, and metric.
    Jun 2012
    Clarkesville, GA
    Thanks for both the replies. I think I know what I need to do now.Thanks again...
    Jun 2012
    Clarkesville, GA
    Well....I just found out that the cap I have is a Moto-techniques design, and apparently (according to others) the set screws can not be accessed from inside the valve cover. Apparently they are designed such that if they come loose they will not fall into the engine.
    Does not look like there is any room to grab the ring from the outside with channel locks, so whatever I do will have to be done from the outside. Wondering if anyone had a similar experience with this particular cap? Thanks...
    have you actually looked inside the valve cover?
    i knew from your description that you had the Moto-Technique's cap (as i suspect PG did as well), and what i gave you for directions is exactly what you should be doing. i've had mine for about 8 years now. and have had to remove, re-install & tighten that inner ring several times. you can ONLY access it from the inside.
    ignore the naysayer(s), and just try our recommendations. use some blue loctite on the set screw if you are really worried about it backing out. fwiw-i have not bothered with it.
    Out of curiosity, did those who said "can't do it" expalin exactly how that part is held in the valve cover if not from the inside?
    Jun 2012
    Clarkesville, GA
    No they did not, only that it is designed to prevent the screw from falling in the engine if it were to back out. Since I did not install it, and really have not paid much attention to it when I took the valve cover off to adjust valves, I am somewhat clueless on how it is put together. I will proceed with your advice though. Thanks again for your input.....
    actually, there is nothing that keeps the set screw from backing all the way out except proper torqueing. if it were to start backing out, you'd see a rapidly worsening oil leak around the outer edge of the insert ring.
    Jun 2012
    Clarkesville, GA
    Moto-techniques just sent me the installation instructions and it looks like from this with the cap installed it blocks the set screws. I'll just have to take the valve cover off and see what I have. Not sure I like this design.
    REMOVE VALVE COVER
    PRESS OUT STOCK PLASTIC INSERT FROM THE INSIDE, OR CAREFULLY PRY
    IT OUT FROM THE TOP SIDE
    START THE SET SCREWS IN THE INSIDE (THREADED) PART OF THE NEW
    INSERT. THIS WILL MAKE IT EASIER TO TIGHTEN THESE LATER. WE
    RECOMMEND THE USE OF LOW OR MEDIUM STRENGTH (BLUE) LOCTITE,
    EITHER NO. 222 OR 243 ON THE SETSCREWS. EVEN WITHOUT LOCTITE, WHEN
    PROPERLY INSTALLED, IT IS IMPOSSIBLE FOR THE SET SCREWS TO FALL
    INTO THE ENGINE AS THEY ARE "TRAPPED" BY THE THREADED PLUG WHEN
    SEATED. HOWEVER, IF THE SETSCREWS ARE NOT SUFFICIENTLY TIGHTENED
    AND/OR LOCTITEÔÇÖD, IT IS POSSIBLE FOR THEM TO LOOSEN ENOUGH TO
    ALLOW THE INSERT TO ROTATE IN THE VALVE COVER.
    LUBE THE INSTALLED VITON O-RING ON THE NEW INSERT WITH ENGINE OIL
    OR GREASE.
    PLACE THE INSERT LOOSELY IN THE TOP OF THE VALVE COVER AND ALIGN
    THE SET SCREWS TO BE PARALLEL WITH THE CENTERLINE OF THE BIKE.
    USING PRESSURE FROM TWO THUMBS, FIRMLY PRESS THE INSERT ALL THE
    WAY DOWN UNTIL THE O-RING FULLY SEATS IN ITS GROOVE IN THE VALVE
    COVER. IF YOU CANNOT GET THE O-RING FAR ENOUGH DOWN TO SEAT,
    PLACE THE VALVE COVER ON A BENCH, PLACE A SMALL BLOCK OF WOOD
    SQUARELY OVER THE INSERT AND CAREFULLY TAP INTO PLACE WITH A
    HAMMER. THE INSERT IS FULLY SEATED WHEN THE TOP OF THE INSERT IS
    FLUSH WITH THE TOP SURFACE OF THE VALVE COVER.
    FROM THE BACKSIDE OF THE VALVE COVER, FIRMLY TIGHTEN THE
    SETSCREWS WITH THE ALLEN WRENCH. INSTALL THE FILLER PLUG AND
    TIGHTEN SECURELY WITH PROVIDED "MINI-WRENCH". THIS TEST ENSURES
    THE SETSCREWS ARE TIGHT ENOUGH TO PREVENT THE INSERT FROM
    TURNING. IF IT DOES SLIP, CAREFULLY TIGHTEN THE SETSCREWS A LITTLE
    MORE. RE-TEST.
    REINSTALL THE VALVE COVER. BE SURE TO NOT DISTURB THE RUBBERSEALING
    GASKET BETWEEN THE VALVE COVER AND THE HEAD.
