Results 1 to 10 of 10
Thread: 2012 rt low speed surge
    May 2012
    Just picked a new r1200rt today,great bike,but a very annoying 1st gear low speed surge,anyone else heard of this?
    Ed Kilner #176066
    Mississauga, ON
    Mine is a 2011. No surge, but a lot of torque. Sometimes, too much twist and it will feel like a surge! Are you sure this is not just you getting used to the throttle?
    Ed
    Jun 2012
    Arroyo Grande California
    Sergio
    I'd agree with Ed. When I first came to my 12R1200RT (from an 1978 R100/7) I struggled some with the high gear ratio starting out and the sensitive throttle. It gets better with practice. Don't spend much time at one speed though when "running in" your new engine. Read that owners manual section "running in"
    Enjoy
    Will Stagg
    Will Stagg Central Coast of Commiefornia
    2012 R1200RT (most awesome unit)
    1978 R100/7 (sidecar tug )
    Yamaha TW200 adventure bikes (3) waay fun units
    'Forgiven'
    Feb 2011
    SW Montana
    I also had this surge with '11. After about 500 mi. it went away..almost. A few thousand miles more down the road I installed the Booster Plug..what surge
    Dana
    God Bless America
    2011RT "Favor"of God
    Jan 2011
    kentucky
    surge
    after about 700 miles the surge went away on my 2011
    May 2011
    have a 12 . No surge from day one. I did stall it in the parking lot at the dealer twice before I was underway. Cold I have stalled the bike a couple times. No surge. Sensitive throttle far better than my oilhead.
    Now 3 months old, 6,000 miles and it still keeps running better. I don't think my bike needs a booster plug. It runs fine the way it is.
    David
    May 2012
    surge
    Thanks for the reply I traded in my 03 1150 I can see
    the getting used to the throttle but the surge is pretty bad,I'll give it some time but what is the plug everyone is talking about?
    Lost again Texpaul's Avatar
    Oct 2006
    San Antonio, Tx
    Having also come to the 1200's from the 1100/1150 lineup I too noticed the sensitive throttle. The problem is made worse (how bad varies by bike and age) by the lean burn conditons off idle dictated by the pollution requirements.
    In very simple, non technical terms, what the Booster Plug does is "fool" the computer into thinking the outside tempurature is 20 degreees cooler than actual. This causes the computer to richen the air/fuel mixture by about 6%. The richer mixture eliminates the portion of the throttle sensitivity created by the stock lean condition.
    So, while the Booster Plug may not completely eliminate throttle sensitivity it does moderate the effect.
    Having said all that I would not install anything until your bike is broken in. As the bike breaks in the engine changes and the throttle response you have now is not what you may have in a few thousand miles.
    Paul Mulhern
    MOA# 56330
    '05 1200GS Big Blue
    Sheboygan, WI
    Smile
    Quote Originally Posted by rhood1960 View Post
    Give it some "time in the saddle." Engine mapping/throttle sensitivity takes several thousand miles to settle in - with the rider as well as the machine.
    The R1200RT is a sweet ride - will never have the low-speed throttle control manners of a V-twin, but still a nice bike.
    Good Luck and Ride Aware!
    Kevin Greenwald - Touring Tips Editor
    MSF RiderCoach # 121656 (BRC,SBRC,IS,IME,SMARTrainer)
    Motorcycle/Driving Instructor - ROAD AMERICA Race Track
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Booster plug. Or, the Accelerator module.
    I use the latter on my '05 GS. It helps at low RPM. Might be different with a camhead.
