Results 1 to 15 of 26
Thread: 98 R1100Rt rear spring
    Ash Grove, MO
    Is it possible and if so, who makes one, to just replace the rear spring on a 98 R1100RT. I don't want the whole shock unit, just want to replace the rear spring with a heavier weight rated spring.
    I checked Race Tech, and they list springs for R1100S, but no RT.
    Mike Davis
    1985 K100RT
    1998 R1100RT
    May 2011
    This guy of Linderman racing says he can put a new spring on my 12 R1200R for $110.
    ed@le-suspension.com This is his Email.
    I think he is right on target with his recommendations.
    David
    Planet Earth
    Jun 2012
    Found this but haven't used. www cannonracecraft com They catalog springs by dimension which would be helpful in some applications.
    just curious- how many miles on the shock?
    Ash Grove, MO
    18000 miles. I'm a firm believer that most 'factory' or OEM shocks are severely undersprung for two up riding. The valving for both damping and rebound are usually sub par too, but the most important step for shock set up is proper spring rates. All the 'clicking' of clickers and 'dialing in' with the 'preload' knob can't fix an incorrect spring rate. And i think the 'preload' knob on the RT is nothing more than an adjustment for damping. But, with the right spring, this adjustment can be very effective.
    I ride two up all the time, with a combined weight of 350 pounds. I know there is no way the stock springs, front and rear, are set up for that kind of weight.
    I have learned from racing dirt bikes on a budget, proper spring rates are the best money spent for the most bang for your buck when it comes to handling and ride quality, so I want to fix my springs on this bike. Ohlins and the likes are way out of the question, but $120 I can do.
    Mike Davis
    1985 K100RT
    1998 R1100RT
    May 2011
    Quote Originally Posted by oldnslow View Post
    I agree, Springs are #1!
    yeah, new springs will help, but those stock shocks are gonna be played out in another 15-20K regardless.
    Jun 2012
    What is your test? With 62,000 miles on my 2002 R1150RT I don't feel any pogo-stick bouncing after a serious bump like a car with worn shocks.
    they will wallow in corners, but should not. they sag, and require jacking up the pre-load just to get them to function. they respond poorly to road irregularities, unable to follow the contour of the road. and yes, they (often) pogo their way down the road.
    i've seen it and felt it. ANY shock is well cooked at 60,000 miles, not just OEM (which are spec'd for nearly all bikes on a basis of cost, not quality). Ohlins and Wilbers and all the rebuildables will require a redo long before 60K.
    hey, if you're happy with how your bike handles, fine and dandy. but for a comparison, try a bike equipped with top end components, and you will feel what you've been missing.
    Jun 2012
    Afraid I'm still lost. To me wallow means the body of a car tilting side to side or end to end or both and the sidewalls of the tires flexing excessively. M/C suspension operating in only one plane with as stiff of components as we have can only move up and down with respect to the tire patch on the pavement. If it oscillates one end then the other like a hobby horse it's simply pogo-ing and of course it needs shocks. And sag is a function of the springs not shocks. Springs that have compressed over time have exactly the same spring rate (lbs/inch) as they had when new as long as none of the coils have already compressed against it's neighbor. I'm relatively sure that a low M/C corners better than a tall one as long as nothing drags so sag isn't a problem until that point. The only reason that I would increase preload would be to prevent excessive bottoming. The last thing I want is over-rigid springs passing more vertical motion to the unsprung weight of the M/C and me where the only force that will pull us back down and regain traction on the tire patch is gravity which seems to take forever when it happens. I can't imagine anything outside of third world motorbikes that would need lots of preload to simply get the suspension off the stops.
    Left Coast Rider
    Vancouver Canada
    Quote Originally Posted by GKman View Post
    I can understand your thought process however there are many things which affect the handling of a motorcycle and ride height is one of them. Typically, a taller bike will turn in more quickly. Further, if a spring is sagged, say half an inch, then that has an effect on the geometry of the motorcycle. As an illustration, put a passenger on your bike with no rear spring adjustment and go for a ride. Very simply put, you've just increased the rake by compressing the rear suspension so you should feel a definite slowing of reaction to your steering input. There are many, many variables which can affect everything I've just said. I'm just pointing out some basics.
    As far as shocks are concerned, in my experience the shocks on my "S" were worn out in fewer than 30,000 km. If the original poster is swapping springs, he may as well "spring" for a shock rebuild/revalve while they're at it.
    Ash Grove, MO
    I have received this info!
    Received this e-mail today...sounds promising.
    "Yes. But you need a crazy tool to do it so you'll have to send me your
    shock. Also I need your spring so I can check the rate, that is my
    starting point. The new spring will be dark red, $110 + shipping.
    Thank you,
    Ed Sorbo
    Lindemann Engineering LLC
    909 838-4587"
    Proper spring rate is important to keep the shock body and valving system in the 'sweet spot' of the shock. A spring that is too soft and the shock valve mechanism is already past the 'small bumps in the road' portion of its stroke and is entering the 'big bump' section of its damping forces. Thats a harsh ride.
    A spring too stiff and, well we know what that feels like. Since the stock shock doesnt have a pre load adjustment on the collar of the shock, I will have to let Lindemann do his math and come up with the proper rate for my weight and riding styles.
    For my amount of miles, the value of the bike, and my riding styles, A new spring is all that will fit my budget. I will investigate the revalving though, since he will have the shock there.
    From his web page:
    OEM without air valve
    Rebuild, including oil & seals $250
    Spring, add $110
    Revalve, add $100
    Total with everything $460
    Mike Davis
    1985 K100RT
    1998 R1100RT
    Jun 2012
    Some times the demands racing puts on parts is amazing. Reading an old Kevin Cameron column from Cycle World. He was only getting two races from Kawasaki 750 crank shafts. A hundred thousand hard miles on the street or 400 on the track. Take your pick. From other sources, want to have a fun weekend at the track in a replica Cobra? Budget for 4 tires. Shocks on Baja buggies in the same category I imagine. But shocks on street bikes? Easy to believe that manufactures won't spend the $$ for state of the art units or be able to accommodate loads perfectly from a jockey sized solo rider to a plus sized North American couple with riding styles from mild to wild. But I'm not ready to buy the idea that ALL shocks will WEAR OUT in less than 50,000 miles. I don't think that they are hammering at either end of the stroke, getting hot enough to blister the paint or being blasted by 100 mph Baja sand. Just a plastic piston in a steel tube with lots of good lubrication. I don't rack up many miles on a vehicle but my wife does. She recently sold a Honda CRV with 175,000 miles. Always had regular maintenance done at one of those places that has the words Service Center not Garage in the name. If they can find anything to sell, believe me they will try. Shocks or struts in 175K? Nope. Still going strong.
    Just noticed that OldAndSlow and I are both from a place called the Show-Me-State. Somebody wants to make me believe shocks wear out quickly on street bikes they will meed to Show-Me and someone confusing springs and shocks is off to a really slow start doing it.
    Ash Grove, MO
    Im far from a shock expert, but, I am confident in saying that until a seal is leaking or a piston is damaged, or the internal oil is heated and its molecular structure is altered, a shock is not going to fail. (But how much thinner can the oil get, it is already 5w oil?) I have seen the shocks on local pro level dirt bike racers go multiple seasons on a single shock. What I do think can happen is the spring will wear out and sag more over time. But to wear out the shock itself in 30,000 miles of street riding, I too find it hard to believe.
    But, I'm open to being educated.
    I wish bike manufacturers would make the springs changeable by the owner. There is a big difference from a 150 pound rider to a 220 pound rider, when they are on a 700 pound bike. The spring rate is like night and day for those two riders.
    Mike Davis
    1985 K100RT
    1998 R1100RT
