Results 1 to 6 of 6
Thread: 1994 K75S: Radiator fan "helicoptering" into the radiator HELP PLZ
    Apr 2007
    Albuquerque, New Mexico
    I tried to search the forum before posting this but something is preventing the Search This Thread tab from opening---sorry if this has been discussed before.
    I just got the fan blades/front motor shroud pried off and can see how this happened in the first place (fan spindle mashes into the back of the radiator).
    Is there any remedy for this? I thought of hot-gluing the fan shroud at the end of the motor shaft but the heat from the radiator would probably melt this and be ineffective.
    Maybe a bit of Fast Steel epoxy putty on the end instead?
    When I install the new fan (hopefully in the next couple of hours today) I'll soft hammer the shroud back on very well and just keep my fingers crossed that it doesn't work it's way up the shaft to rejoin the back of the radiator which it seems prone to do. I wonder if grinding off the round bushing or nub at the front of the shroud is a good or bad idea?
    This must have been what caused my chirping noise all along! Oh, well, now I have a brand new radiator fan that I won't have to worry much about and I can always sell the old fan motor to recoup some of my expense; it appears to be fine (I'll run it on my adjustable power supply a good while to make sure).
    ---Jeff '94 K75S Berlina
    ex: R100GS/PD , K100RS , R75/5 , R60/2
    Apr 2007
    Lightbulb Another idea
    Maybe it would be a better preventative to apply a small amount of Fast Steel onto the damaged fins and core of the radiator instead of on the fan shroud.
    That way, if the blades/shroud ever creeped back up the motor shaft it would hit the solid-as-steel Fast Steel and do no further damage.
    Unless I hear otherwise I think that's what I will do after I clean everything up before reassembly.
    Apr 2007
    Fan/radiator assembly installed now and I put a small patch of Fast Steel on the damaged area as planned. If the shroud ever starts to helicopter into it again it will hit the steel epoxy instead.
    Pix to follow...
    Apr 2007
    Smile Done!
    A bit late but here are the pix I promised;
    BEFORE
    AFTER
    THE CULPRIT (the metal nib in the center of the propeller was rubbing/mashing into the radiator backside causing all the screeching as well as some minor damage caught in time)
    radiator fan
    What I have done is replace the fan motor on the k1100 once. Lasted maybe 6 months due to buying it from a bmw grave yard.
    Now I have an after market fan fastened to the front of the radiator and removed the fan from the rear.
    Then watching the temp or in slow traffic turn on the aftermarket fan. Works. i average 15,000 miles per year and this set up has been on the bmw for the last 3 years.
    Tim
    1995 K1100RS, 127,000+
    Apr 2007
    Sounds like a brilliant solution that you worked out there, Tim.
    Still either haven't had a chance to go for a ride since I installed the new fan motor or it's too darn cold but I strongly suspect that it'll be fine for a long time to come.
    Hopefully I won't be adding anything further to this thread for a long time.
