Results 1 to 10 of 10
Thread: Crankshaft moved forward
    Georgia SUNRIDER711's Avatar
    Mar 2005
    Lubbock, TX
    I was trying to put in a clutch on a 1980 R100RT, the crankshaft moved forward.
    Is there any hope for this machine?
    Yes, but it's going to be a pain in the butt. This is going to require some engine disassembly. Read what Snowbum has to say:
    http://bmwmotorcycletech.info/flywhe...valwarning.htm
    You might be able to see if thrust washer as moved...if not then, you might have dodged a bullet. But you have to at least investigate.
    Monza Blue 1974 R90/6
    Delaware
    How did the crank move forward? You had the flywheel off?
    Barron
    Mar 2005
    Lubbock, TX
    Flywheel was off,,,, didn't block the crank.
    I previously replaced the clutch on my 1979 R100RT twice with no problem.
    Ooops...third time wasn't the charm... Sorry...
    Fixes Gauges tvrla's Avatar
    Oct 2004
    Portland, Oregon
    Good thing you noticed and didn't just try to bolt it back up and cinch it down!!!
    It may seem like a lot of extra trouble at this point but it could be much MUCH worse! I've also done a clutch without blocking the crank - must have been fifteen years ago before I got smart. Was lucky that time like you were the other the fast two.
    Sep 2007
    Youi may not be in trouble. The thrust washers on either side of the crankcase usually resist falling out of position. Carefully push the crank back, then put the flywheel on. If it seats, you're probably OK. If not, you'll have to pull the right cylinder and "fish" the washer back into place.
    Oct 2009
    Northern Cal
    The easiest fix is to pull the right cylinder off which is closest to the thrust washer and try and work it back on.
    www.boxermetal.com
    www.facebook.com/boxermetal
    #4869 DennisDarrow's Avatar
    Sugar Valley, Ga
    Perhaps a dumb question; but......why did you have the flywheel off to just work on the clutch?......Good luck......God bless...Dennis
    Oct 2004
    Portland, Oregon
    Quote Originally Posted by DennisDarrow View Post
    Probably replacing the rear main or oil pump seals
