Results 1 to 6 of 6
Thread: K100 ABS brakes Repair Suggestion
    Registered User blackbeauty's Avatar
    Oct 2005
    Canton, GA
    Lightbulb K100 ABS brakes Repair Suggestion
    Looking at a k100s 1989 with low miles. The ABS brakes not working, can they be rebuilt? Some have suggested to remove them reducing weight while using disc brakes. I prefer to keep it original with ABS brakes.
    Aug 2012
    Quote Originally Posted by BlackBeauty View Post
    Yes, they can be rebuilt. I saw it somewhere on this website. Don't remember which thread. If you keep your bike original with ABS brakes, you should get a discount on your insurance. I did.
    Lynn
    MOA #57883
    Registered User beemerguru's Avatar
    Foster City, CA
    How are they not working? Flashing lights, can't be reset, not stopping?
    Competent dealer changed all the fluids and reset the system?
    Greg Hutchinson
    R80G/S (4) 633CSi with 450K mile
    '68 R60/2 '88 K100RS Special Edition
    http://gregsgssite.shutterfly.com/
    as beemerguru implied, there are multiple reasons why the ABS is malfunctioning. (thus, the question about what the lights are doing, as they give a clue as to the cause).
    this can be anything from it needing a new battery (a relatively cheap and very predictable expense), to a failed ABS pump/controller (probably cost as much as the bike is worth, especially if repaired at a dealership), and likely a few other possibilities in between.
    if you can't assess the reason why the ABS is out, and you don't have anyone that can do that assessment for you- think of the bike as a non-ABS model that is going to require some heavy parts to be removed and replumbed. now... do you still want that bike? otherwise, you could be in for a cheap repair (~$100) or a very expensive one (meaning north of $2000)- with no way to figure out in advance which it is.
    you did mean K100RS, correct? (BMW never made a K100S model).
    Apr 2007
    Rockport, TX
    Exclamation
    If it's something like a low voltage scenario all you need is a piece of wire run to ground and the other end stuck into a 3-socket connector to reset it.
    A$3 LED from Radio Shack can tell you the fault code so you know what the problem is; don't give up the ship quite yet!
    ---Jeff
    Astatula, FL
    Diagnostics
    Look here for articles on diagnosing ABS faults and resetting.
    http://www.ibmwr.org/ktech.shtml
    Look under Gauges-Electrical-ABS.
    There is an outfit that rebuilds the ABS controller for a reasonable price, cant locate it right now.
    Bob Weis
    '04 K12RS - Hannigan Hack
    www.earplugco.com
