How do you get the ignition switch out of the RT fairing? Does that little plastic piece just spin off?
<<<Les Garten>>> 58624
www.boxermetal.com
www.facebook.com/boxermetal
www.boxermetal.com
A pair of snap ring pliers is what some of the old manuals suggest, and what I have used since 1977. The type that can be converted from internal to external, in an appropriate size seems to work best.
I'd put some lube (perhaps a silicone-based one) on the outside of the ring, and give it some time to dribble into the threads that hold the ring in place. Then, needle-nose pliers, held perpendicular to the ring with the tips in the holes, and carefully rotated. Keep some downward force (pushing the tips in the holes) on the pliers as you rotate them.
David Brick
Santa Cruz CA
2007 R1200R
I can send you the tool but I need someway of knowing I will get it back.
www.boxermetal.com
aka: a deposit. Perhaps?I can send you the tool but I need someway of knowing I will get it back.
Lew Morris
1973 R75/5 - original owner
