Results 1 to 8 of 8
Thread: Gerbing heated jacket use on a 01-k 1200RS
    Kawa Afterthought weschmann's Avatar
    May 2012
    DeSoto MO
    Looking for some feedback on use of a Gerbing heated jacket with my K1200 RS. I just picked up a slightly used jacked from a BMW member in Ohio, who said that the Gerbing jacked should not be used on any bikes with the Canbus system, since it draws 7.5 amps and the Canbus system is rated only to 4 amps....??? Amy feedback would be appreciated, as I have never used any heated clothes before. This is the first time I've had a power-port available to plug into....
    So my question is, does the 01 K bike have the Canbu system or am I good to go....?
    Mar 2007
    Chicago, Ill
    You are good to go
    Canbus on the Ks came in later - 2005?. Plug in and enjoy the warmth!
    May 2012
    DeSoto MO
    Beemer01, thanks for the quick reply.... I was just getting ready to figure out how to hook up a cigarette lighter left-over from my Kawasaki days.... Bought but never installed.... so now I don't have to find a place to mount it......
    Sep 2007
    I prefer to connect a Gerbings lead direct to the battery. BMW's power socket can get quite warm when running a jacket liner.
    Mar 2007
    Chicago, Ill
    Adjustable heat
    If the jacket didn't come with a a thermostat, suggest you get one. Most operate on a switchmode basis - turning the heat on and off many times every minute. You just notice that the heat can be turned up or down depending on your requirements - reduces load on alternator and plug, tho I've never noticed that my plug getting hot.
    Also much easier than turning it on and off.
    rabid reader dbrick's Avatar
    Santa Cruz CA
    And make sure you have a fuse in the line, too.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Registered User DJOHNSON141421's Avatar
    Apr 2005
    Escanaba, Michigan - Michigan's Upper Peninsula
    heated
    I have a 2000K1200RS k12rs. A thermostat is a must IMO. Makes riding in cold temps. more enjoyable. No problem with your bike and wiring.
    May 2012
    DeSoto MO
    Thanks to everyone for the information.... I've purchased a duel controller, and some heated gloves, and have to wonder why I didn't buy a MC earlier that has the capability to support the amp's draw... The last 2 days, early morning temps have been in the lower 40"s, and I have been toasty on my ride up to the Mickey D's coffee klatch meeting.....without needing to wear my leather jacket.....So come on single digits..... Might have to pick up a pair of heated slacks to go with the jacket, at some time in the future....
