Results 1 to 11 of 11
Thread: Left to Right wobble at slow speeds
    Registered User pschuyler's Avatar
    Oct 2008
    Prosper Texas
    Ok, I'm stumped.
    2000 R1150GS
    I have noticed at slow speeds 30 and below the bars are wobbling left to right when hands released (I know do not release hands), but I'm starting to get annoyed by this.
    Things I have ruled out so far
    Wheel out of balance ( had it relabalnced just in case)
    Tire pressure (good)
    Sticking brakes (brake drag on front is a little more than I would like)
    Steering head bearing (good)
    Wheel bearings seem ok (no noise and very smooth)
    Cleaned out calipers (anyway)
    Bled air out of fork tubes
    Front shock/strut only has 5K miles on it
    Anyone else experience this issue? What next to look for?
    Peter Schuyler
    Feb 2010
    Dennis, MA
    scalloped tires?
    John Simonds
    2008 R 1200 GSA
    1975 850 Norton Roadster
    If it ain"t broke... fix it till it is.
    Oct 2008
    Prosper Texas
    Quote Originally Posted by junkjohn View Post
    scalloped tires?
    Tires are fairly new, 3K miles, look good from the side and front.
    Mich Road Pilot 3 Traill version
    Peter Schuyler
    Ball joint on telelever? How many miles on the bike? The K12 Wedges do this with bad ball joint.
    Steve Henson
    Oct 2008
    Prosper Texas
    The bike has 58K miles, to be honest I would not have thought of that. That ball joint seems kinda of hidden.
    Is it easy to replace?
    Peter Schuyler
    SE Wisconsin
    Quote Originally Posted by pschuyler View Post
    Ok, I'm stumped.
    2000 R1150GS
    What frequency is the wobble?
    What brand of tire?
    What Tire pressure are you running?
    I had an Avon, and a Pirelli that both exhibited that 'feature', after about 4k on the front. Probably about a 5 Hz wobble. changing tire pressure helped, but stopped using those brand tires and it never returned.
    Left Coast Rider
    Vancouver Canada
    This kind of thing is typically tire related as has been mentioned.
    If you're happy with the way the bike handles when you're not doing handstands on the seat entertaining passersby, I wouldn't worry about it.
    But that's me.
    Nov 2005
    Fairfax, VA
    I also suspect the tires, but one additional Q: have you checked for play in the bearings between the rear of the swingarm and the final drive? A known wear spot.
    FWIW, I learned a couple decades ago that if you are feeling a handling quirk at one end, look that the other end as the most likely source.
    Mark Neblett
    Fairfax, VA
    #32806
    Check both the front and rear wheels for runout. A bent wheel would be my first suspect, after a bad tire.
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    possibly a broken cord in the front tire??
    Ken
    IBA #44567
    -Albert Eienstein
    Lucky motorradmike's Avatar
    Jun 2008
    Ontario
    If it does it at parking lot speed you could try reducing front pressure way down just for a test.
    Might be informative and really easy to do.
    My guess is bad front tire.
    Mike Marr
