Results 1 to 4 of 4
Thread: K 1200 S ESA issue
    May 2010
    K 1200 S ESA issue
    Having an issue with the ESA not wanting to switch between 1 rider, 1 rider with luggage and 2 rider modes. Does anybody have an idea what would cause this?
    DrPaul DrPaul's Avatar
    Apr 2007
    Bartlesville, OK
    Quote Originally Posted by 1998gsrt View Post
    The adjustment can only be made when the motorcycle is stationary with the key on. BMW recommends unloading the bike to make the changes.
    DrPaul - 2008 K1200GT
    2004 R1150RT - sold,1974 R90/6 - sold
    2002 R1150RT - sold,1987 K75S - sold
    Registered User john1691's Avatar
    Nov 2005
    Lancaster County, PA
    Could be a pinched wire. Some of the GT's have had an issue with the routing of the wire, which then got pinched/rubbed. Follow the wire from the shock, make sure it doesn't have any wear spots.
    john1691
    2006 KTM 950 Super Moto
    Jul 2007
    Evansville, WI
    What position is it in now?
    Mine was stuck in "solo" position, no matter what I tried (I'm assuming you have tried it various ways too and that it's really "stuck" like mine was.
    Called the dealer to ask what they recommend, since, get this, a new shock costs $2500, yes twenty five HUNDRED dollars.
    They said to bring it in as often if they use the shop computer to do a "reset", which it seems like is actually having the computer "command" the ESA motor to run, that it might free it up. I did that and they did get it to run. Moral is to operate the preload system from time to time, if you (like me) normally don't even use it. And another train of thought is to leave it in the middle position as it might not stick in the middle like it does on solo or max position.
    I was lucky, the dealer didn't charge me to do this, I have heard that other dealers have charged a pretty hefty amount just to have their computer talk to the bike's computer. Gave the service tech a Jackson and called it a day.
    I have a thread here someplace about this, I will try to link you up.
    Gilly
    Here is the thread I started, but is at K-Bikes.com, I am there quite a bit as well:
    http://www.k-bikes.com/forums/showthread.php?t=25639
    87 K75S, bought new, now sold
    13 C650GT
    MOA 44606
