Results 1 to 15 of 26
Thread: booster plug installation r1200r
    mattituck new york
    looks to me like the tank gotta come off to stick the BP in there.
    zat right?
    this is an rt, i think. i have an r
    Nov 2005
    Fairfax, VA
    Yep.
    Mark Neblett
    Fairfax, VA
    #32806
    Lost again Texpaul's Avatar
    Oct 2006
    San Antonio, Tx
    You don't have to remove the tank to install the BP. You can get by with just sliding it back enough to raise the rear and allow access to the airbox. Of course by then you've done almost everything needed to remove the tank except disconnect the fuel lines and lift it off.
    Just saying, installation can be done without removal.
    Paul Mulhern
    MOA# 56330
    '05 1200GS Big Blue
    mattituck new york
    thanks mark/paul
    the instructions whut come wif it didn't say nuffin' about takin' the tank off or movin' it around..
    not a big deal but if you're not too smart like me it woulda made it simpler to figger out where to stick it.
    thanks, genamins...i'm headed out to the garage.
    "The only thing to do with good advice is to pass it on. It is never of any use to oneself."
    Oscar Wilde
    Outlander Omega Man's Avatar
    Mansfield,MA
    It's not you....A friend of mine gave me a BP to try, his a Hex/Cam and mine an F800. A lot of digging shows that it should be the same device but the relevant instructions, no doubt, were written by someone that has done the install many times and forgotten to mention the "little things"
    2009 F800GS 1994 TW200
    Part of the Forum Threadside Assistance Program
    Since every R tank config is different...I wouldn't have thought you had to go that far...the airbox is more exposed on the RT & GS when you pull the covers off.
    Steve Henson
    mattituck new york
    my bike
    looks like i can get at it leaving fuel and electric lines connected. be nice to have an extra set of hands, though.
    probably should be doing this this AFTER the 6k mi check. anybody think i should tell the dealer the PB is in there? i'm inclined not to mention it.
    BinkleyLane binkleylane's Avatar
    Jul 2012
    Springboro, OH
    My dealer did not have any issues with the BP on mt RT.
    The tech that did the service and short road test actually commented on how smooth the bike was.
    I agreed.
    B-est M-otorcycle (in the) W-orld
    Have Bike - Will Ride
    mattituck new york
    well, i slaved it it and cranked it up
    idles at 1100 (cold) rpm or about 100 rpm higher than before. ain't buttoned it up and took it out yet. sposed ta rain tomorrow.
    bmwk100
    Quote Originally Posted by f14rio View Post
    I'm about to do my 24K mile service and was thinking the same thing. I'm concerned that they would "detune" the bike if they don't know it's in there. (I picture them hooking up the computer, seeing that the bike was not within regular specs and detuning it.) Any thoughts?
    'Forgiven'
    Feb 2011
    SW Montana
    This is what I did..no tank moving needed..
    Hope this helps
    Dana
    God Bless America
    2011RT "Favor"of God
    mattituck new york
    you got a 'rt'. i got a 'r''
    whatsamattayou?
    Jul 2012
    Springboro, OH
    Quote Originally Posted by bmwk100 View Post
    That is a great question. I will email the folks at BT and get an answer. I'll post it when they respond.
    Jul 2012
    Springboro, OH
    Here is the responce to your question from Booster Plug.
    The short answer is that you can just leave the BoosterPlug installed when you take your bike to service. There's nothing anyone can do to cancel the effect of our device. Period.
    Here's the long and more technical version:
    ÔÇóAs you probably know, the BoosterPlug basically works by telling the Fuel Injection Computer that the weather is colder than the actual temperature.
    ÔÇóWhen the temperature drops, the air molecules sticks closer together, meaning that there's more air molecules in a gallon of air in low temperatures than in hot weather. This means that the Computer must inject more fuel in low temperatures to keep the same Air/Fuel Ratio.
    ÔÇóThe good thing here is that the characteristics of air molecules behavior is well known, and this characteristics is preprogrammed into the Fuel Injection Computer to make it possible to compensate the mixture in colder weather. I've checked a lot of different brands of Fuel Injection Computers, and this compensation is always the same because it must follow the characteristics of the air that our engines (and we) breathe.
    ÔÇóAs all engines obviously operate in the same kind of air (as there's only one kind), this compensation is never adjustable in any Fuel Injection Computer, and that's why it's not possible to detune the BoosterPlug.
    I should probably also mention that tweaking the air temperature signal is not a new idea - this have been done as long as electronic fuel injection have been around.
    The problem is just that the original Air Intake Temperature sensor is not a linear output device, so it's not that easy to come up with a solution that will provide the same fuel enrichment in different ambient temperatures.
    This is where the BoosterPlug really stand head and shoulders above the hobby solutions.
    Great question and I think I understand the answer.
    You can email them direct from their web site if you have other concerns. They have alswas bee very prompt with me.
    Jul 2012
    Springboro, OH
    Hey Pipestone,
    Where do you have the termistor ( temp sensor ) placed. I see it in the pic, is that where you leave it?
