Results 1 to 6 of 6
Thread: '11 RT RPM fluctuation
    May 2011
    Portage, MI
    probably just a bit of paranoia on my part. Any one else experience RPM fluctuation a few hundred RPM when the bike is in neutral and you hold the throttle in the 2-3.5kish range?
    Feb 2012
    Stanwood, WA
    RPM Fluctuation - 2011 RT
    Quote Originally Posted by klumbsh1 View Post
    I haven't experienced any fluctuation, but then I can't say that I recall trying to hold the throttle in the 2,000 to 3,500 rpm range while in neutral. I guess I'll have to try this. To date though, I haven't experienced any throttle instability during normal use.
    May 2006
    Northern New Jersey
    Why would we want to hold the throttle at 3,500 while in neutral?
    2011 R1200RT - (Thank You, MOA!)
    1978 Honda Hawk 400
    May 2011
    Portage, MI
    Quote Originally Posted by ClassicVW View Post
    TB sync for one.
    There isn't any fluctuation under normal load.
    Jun 2008
    SF Bay Area
    TB sync for one.
    Off idle TB sync should be done slightly off idle. 1400-1800 RPM is specified for the earlier hexheads. I assume it is the same for the camheads.
    May 2011
    Smile
    I think its normal. Its the computer chasing the o2 sensor with no load. Does it really matter?
    Matching the cables just off idle is where it works the best. The further open the throttle is, the less it matters.
    David and my two cents.
    2012 R1200R 6,000 MIles
    2011 Versys 12,000 Miles
    2000 R1100RT 137,000 miles
